M55 System Counter & System Timer register map html/xml request
I am working with the M55 core and more specifically on the System Counter & System Timer.
I found the documentation at -
https://developer.arm.com/documentation/101370/0000/System-time-components/System-Counter/Programmers-model/CNTControlBase-registers-summary?lang=en
https://developer.arm.com/documentation/101370/0000/System-time-components/System-Timer/Programmers-model/CNTBase-Registers-Summary?lang=en
Is there an available html/xml depicting the register map in a clean & concise way for these registers?
Thank you in advance to any helpers
