I am doing an MMU experiment with Raspberry Pi 3B (Quad core Cortex A53) board. The board starts in EL2. From EL2, the stage-2 MMU is configured. It is configured to have a one-to-one mapping (that is Intermediate Physical Address and Physical Address are same). The code in EL2 is continuing to execute after the MMU is enabled (HCR_EL2.VM=1). But when the code switches to EL1 (After ERET instruction), the memory contains random data. If I inspect the memory before ERET, using a debugger, it contains valid code. May I know the reason for this?
The page table configuration uses 64KB granule. The Level-2 table entries points to 512MB blocks. For reference, the important steps of my configuration is given below. Any hint is greatly appreciated.
ldr x1, =tt_s2_l1_base msr vttbr_el2, x1 movz x0, 0x755c movk x0, 0x0001, lsl 16 //64KB granule, 512MB block msr vtcr_el2, x0 ldr x1, =tt_s2_l1_base // Address of L1 table movz x0,0x0000 orr x0, x0, 0x01 orr x0, x0, 0xc0 orr x0, x0, 0x400 orr x0, x0, 0x300 str x0, [x1] //first page table entry configuration dsb SY msr sctlr_el1, xzr isb tlbi VMALLE1 dsb SY isb mrs x0, hcr_el2 orr x0, x0, #0x1 //enable stage-2 address translation orr x0, x0, #(1<<31) // RW=1 EL1 Execution state is AArch64. msr hcr_el2, x0 movz x2, 0x03c5 //DAIF masked movk x2, 0x0000, lsl #16 msr spsr_el2, x2 //Saved program status register movz x0, 0x0000 movk x0, 0x100, lsl #16 msr elr_el2, x0 isb dsb SY eret
