I am checking the GICD_IERRR bit before the GIC and GICT configuration.
Flow is as follows
1) Check the GICD_IERRR during boot sequence.
2) Intialise the GIC register.
3) configure the GICT
In step 1 , found the GICD_IERRR bit is set. Found the recovery mechanism from Spec : Arm® CoreLink GIC-600 Generic Interrupt Controller Revision: r1p6" Page 84 for SPI SRAM.
Can I do recovery mechanism in step 1 when IERRR bit set? Is it showing SRAM hardware issue which can not be recover? Is recovery mechanism is applicable only when GICT catch the error?
