L2ACTLR[7] bit need to set on power SBL on or in application is also possible
Hi ,
   we are facing issue 798870: A memory read can stall indefinitely in the L2 cache, to work around to set L2ACTLR [7], we need to set the bit in SBL or we can mange setting the bit in application?
