When GICD_IERRR bit set ?
I am using GIC600. I found one unusal thing related GICD_IERRR bit. During bootup sometime i saw GICD_IERRR bit is set. I am checking all GICD_IERRR bit before configuring distributor, CPU interface and redistributor.GICD_IERRR bit indicate SPI RAM error only or it indicate different error also?
Thank you in advance for your time and support
  • No, it is not SPI RAM.
    SPI is a concept defined by Arm GIC specification, which means Shared Peripheral Interrupt.
    <quote>
    The GIC can deal with four different types of interrupt sources:
    • Shared Peripheral Interrupt (SPI). Peripheral interrupts that can be delivered to any connected core.
    • Private Peripheral Interrupt (PPI). Peripheral interrupts that are private to one core. An example of a PPI is an interrupt from the Generic Timer.
    • Software Generated Interrupt (SGI). SGIs are typically used for inter-processor communication and are generated by a write to an SGI register in the GIC.
    • Locality-specific Peripheral Interrupt (LPI). LPIs were first introduced in GICv3 and have a very different programing model to the other three types of interrupt. The configuration of LPIs is covered in the Arm CoreLink Generic Interrupt Controller v3 and v4: Locality-specific Peripheral Interrupts guide.
    </quote>
    For details, please refer to: developer.arm.com/.../Arm-GIC-fundamentals
  • There are two RAM(SPI0,SPI1) avalible for Shared Peripheral Interrupt in GIC. GICD_IERRR register shows error related to RAM part. Refer Arm® CoreLink  GIC-600 Generic Interrupt Controller Revision: r1p6. Page 84
  •   Can you please help me to find the answer? Thank you for your time
