Migration from Cortex M4 to Cortex R5F
Hi Champs,
I intend to migrate from Cortex M4 to Cortex R5F. As I understand both the CPUs seem very similar in a lot of aspects MPU, instruction set and yet is very different from the other. I am using ARM-CLANG as a compiler so I am not worried about the instruction set.
I would like to know which are the major points where I would have to change my software like interrupt handling, startup (maybe ?), systick handling.. Can I get an overview with this information ?
Best Regards,
Aakash
  • You might find this resource useful - Cortex-R Programmer's Guide.
    The exception model on the R profile is very different to M profile.  So expect to need to make changes to all the things you mentioned.
  • You mean, the major difference is between how the NVIC and VIC works ? How does SW handing has to change for the same ?
  • Migrating from Cortex-M4 to Cortex-R5F would require you to make some changes to your software. Here's an overview of some of the major points:
    Interrupt Handling: Cortex-R5F has a different interrupt controller compared to Cortex-M4. You would need to update your code to handle interrupts in a different way.
    Startup: Cortex-R5F has a different memory map compared to Cortex-M4. Therefore, you would need to update your startup code to correctly initialize the new memory map.
    Systick Handling: Cortex-R5F has a different Systick timer compared to Cortex-M4. You would need to update your code to handle the new Systick timer.
    Cache and Memory Protection: Cortex-R5F has an MPU (Memory Protection Unit) and cache memory which are not present in Cortex-M4. You would need to modify your code to take advantage of these features.
    Floating-Point Unit: Cortex-R5F has a dedicated floating-point unit (FPU), while Cortex-M4 has a separate FPU or none at all. If your code uses floating-point operations, you would need to modify it to take advantage of the Cortex-R5F FPU.
    These are some of the major differences that you would need to consider when migrating from Cortex-M4 to Cortex-R5F.
