LPC1850 with S25FL256 SPI FLash
on my board, LPC1850 is interfaced with S25FL256 over SPIFI. I want to debug my code in S25FL256 using debugger. I am using ULINK2 debugger.
W hen I try to program the external flash (S25FL256) using debugger, I get the following error message :
Flash timeout - Reset the target and try again.
Error: Flash download failed - "Cortex M3"
Please check screenshot of my settings in keil attached here.
I created new flash algorithm for S25FL256 by modifying  source code on path c:\Keil\ARM\Flash\LPC18xx43xx_S25FL032. I added following code in FlashDev.c file and created new .FLM file and selected this new flash algorithm in keil setting.
struct FlashDevice const FlashDevice =
      FLASH_DRV_VERS,                                // Driver Version, do not modify!
      "LPC18xx/43xx S25FL256 SPIFI",           // Device Name
       EXTSPI,                                                   // Device Type
       0x14000000,                                            // Device Start Address
       0x02000000,                                            // Device Size is 32MB
       256,                                                          // Programming Page Size
      0,                                                              // Reserved, must be 0
      0xFF,                                                        // Initial Content of Erased Memory
      500,                                                         // Program Page Timeout 100 mSec
      5000,                                                       // Erase Sector Timeout 3000 mSec
      // Specify Size and Address of Sectors
      0x001000, 0,                                            // sector size 4 KB (32 sectors)
      0x010000,0x20000,                                 // sector size 64 KB (510 sectors)
      SECTOR_END
I dont understand what is wrong.  Can you help me to fix this issue??
Thanks,
Santosh Mengade
