How to build the android12 image available for Fast model?
I'm having some problems building the android12 image.
I downloaded and compiled AOSP, branch android-12 and lunch aosp_arm64-eng. To use the gga, made myimage.img with ramdisk.img and system.img under the android out folder according to Fast Models User Guide (arm.com)
Here is my start command:
./FVP_Base_RevC-2xAEMvA --plugin=../../plugins/Linux64_GCC-9.3/Sidechannel.so
-C DEBUG.Sidechannel.interceptor=$PVLIB_HOME/GGA/reconciler/linux-x86_64/gcc-9.3.0/rel/libReconciler.so
-C pctl.startup=0.0.0.0
-C bp.secure_memory=0
-C cache_state_modelled=0
-C cluster0.NUM_CORES=1
-C cluster1.NUM_CORES=0
-C bp.smsc_91c111.enabled=1
-C bp.smsc_91c111.mac_address=auto
-C bp.pl011_uart0.untimed_fifos=1
-C bp.secureflashloader.fname=fvp_bl1.bin
-C bp.flashloader0.fname=fvp_fip.bin
-C bp.virtioblockdevice.image_path=image/myimage.img
But it stuck in the following interface:
I think there may be some problems with the android image produced, and the fast models user guide is too brief. How can I correctly build an android12 image and Device Tree Binary that can be used by fast models? What files do I need to prepare to run android under fast models?
Thanks!
