GIC600AE - GICA frames: Registers for message-based Interrupts
GICA frames are used by devices like PCIe controllers that support MSIs so that they can issue a dma transactions to set pending SPIs.
The number of interrupts that can be set shall be within the range specified on GICA TYPER.
[28:16] INTID: The INTID of the lowest or first SPI that is assigned to the frame.
[10:0] NumSPIs: Returns the number of SPIs that are assigned to the frame.
Q1: What if I try to set an out of range IRQ? what would be the expected behavior?
1st assumption: we have a GICv3 implementation with GICv2m extensions (only one GICA frame is supported).
2nd assumption: we have a virtualized environment with two dedicated VMs driving two different PCIe controllers.
- The SMMU shall be set in a way that allows the each PCI controller to write to the GICA frame.
Q2: How can we prevent each VM from set/clear interrupts that are not assigned to it?
This breaks VM isolation since a VM can maliciously set/clear interrupts on other VM. Is my understanding correct?
If so, what could be the suggested hw configuration to have proper isolation?
