Hi all,
there is a remarkable difference in the encoding of the MPU Region Access Control Register setting (DRACR) documentation in :
- the (actual) TRM : DDI0458D_cortex_r7_trm.pdf (TRM Rev D. Dec 2016)compared with the (actual) architecture refernce manual : DDI0406C_d_armv7ar_arm.pdf (29 March 2018 )
Table 8-2 TEX[2:0], C, and B encodings (page 152 DDI0458D_cortex_r7_trm.pdf)
TEX[2:0] C B Description Memory type Shareable?--------------------------------------------------------------------000 0 0 Strongly Ordered. Strongly Ordered Shareable000 0 1 Shareable Device. Device Shareable000 1 0 Reserved. - - << "Reserved" for TEX = 000, C = 1, B = 0 << encoding for "000 11" missing001 0 0 Outer and Inner Non-cacheable. Normal S bit..
Table B5-4 C, B and TEX[2:0] encodings (page 1754 in DDI0406C_d_armv7ar_arm.pdf)
TEX[2:0] C B Description Memory type Shareable?--------------------------------------------------------------------000 0 0 Strongly-ordered Strongly-ordered Shareable000 0 1 Shareable Device Device Shareable
000 1 0 Outer and Inner Write-Through, no Write-Allocate Normal S bita << "normal" write through for TEX = 000, C = 1, B = 0000 1 1 Outer and Inner Write-Back, no Write-Allocate Normal S bita << "normal" write back for TEX = 000, C = 1, B = 1
001 0 0 Outer and Inner Non-cacheable Normal S bita..
Which documentation is correct for the CortexR7 ?
First of all it's very disapointing, that arm leave us behind with this question.
We think that the description in the Architecture manual is right at this point,
The Lauterbach Trace32 debugger decode the mpu regions by using the settings from this Manual.
BR
In CR7 TRM, it is mentioned that the Write-Through cache policy is not supported.CR7 does not support Write Back no Write-Allocate. All Inner Write-Back memory is treated as Write-Back Write-Allocate ignoring any cache allocate hint, though this can dynamically switch to no Write-Allocate, if more than three full cache lines are written in succession.
