CA55 snoop response behavior when cache line is clean
A system with CA55,DDR,System NOC Which interconnected using a CCI550.
1.CA55 Read address 0xA from DDR and store in cache.
2.System Noc send read address 0xA to CCI550
3.CA550 snoop filter hit then send snoop command to CA55.
4.CA55 has 0xA cache clean data,then CA55 will return snoop data or not?
  • From a protocol perspective, the Cortex-A55 / DSU are allowed to do either if the line is clean - it can choose to return the line or signal that it has the line but is not returning data.
    The ACE specification recommends that for certain transaction types, data is returned even if it is Clean - see Table D5-6 in the in the AXI/ACE Specification Issue H.c.
