Hello.
A lot of years ago I bought the Samsung XE303C12-A01US Chromebook. I played with it on 2013 and then it remained on the shelf until today. I would like to install and boot a linux distro through the sd card that has a kernel that supports qemu and kvm. I've found this old tutorial :
http://www.virtualopensystems.com/en/solutions/guides/kvm-on-chromebook/
and my host os is Linux Ubuntu 22.04. These are the commands issued based on the tutorial :
# apt-get install build-essential git u-boot-tools qemu-user-static gdisk cgpt libncurses5-dev flex bison vboot-kernel-utils debootstrap gcc-arm-linux-gnueabihf # wget www.virtualopensystems.com/.../uImage # wget www.virtualopensystems.com/.../guest_zImage # wget www.virtualopensystems.com/.../exynos5250-snow.dtb # wget www.virtualopensystems.com/.../rtsm_ve-cortex_a15x1.dtb # git clone git://github.com/virtualopensystems/linux-kvm-arm.git # cd linux-kvm-arm # git checkout origin/chromebook-3.13 -b chromebook-3.13 # curl www.virtualopensystems.com/.../config > .config # ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- make uImage dtbs -j4 CHK include/config/kernel.release CHK include/generated/uapi/linux/version.h HOSTCC scripts/conmakehash CC scripts/mod/empty.o HOSTLD scripts/dtc/dtc /usr/bin/ld: scripts/dtc/dtc-parser.tab.o:(.bss+0x50): multiple definition of `yylloc'; scripts/dtc/dtc-lexer.lex.o:(.bss+0x0): first defined here CC scripts/mod/devicetable-offsets.s In file included from include/linux/compiler.h:54, from include/uapi/linux/stddef.h:1, from include/linux/stddef.h:4, from /home/ziomario/Scrivania/chromebook/linux-kvm-arm/include/uapi/linux/posix_types.h:4, from include/uapi/linux/types.h:13, from include/linux/types.h:5, from include/linux/mod_devicetable.h:11, from scripts/mod/devicetable-offsets.c:2: include/linux/compiler-gcc.h:103:1: fatal error: linux/compiler-gcc11.h: File or directory not found 103 | #include gcc_header(__GNUC__) | ^~~~~ compilation terminated.
