Mixed Core Memory Usage
This is not  a Big.little question - this is for non homogeneous cores with possibly different instruction sets, and different schedulers (different OSs on each core).
What does system memory look like from a heterogenous chip that is ARM A/R or ARM A/M?
Is it or can it be  shared based on physical address range segmentation?
Can memory be shared between different core types (Same Memory/Flash Chip, but with internal bus managed by the mixed core HW).
I have seen some examples of this but have not seen HW application notes for mixed core usage of RAM.
Basically, what does the bus architecture look like, and can you direct me to relevant HW/SW application notes?
