What's the single cycle Load-Use in ALU mean?
This is in the follow picture:
According to http://www.arm.com/files/downloads/Enabling_Embedded_Innovation_with_the_Cortex-A7_Processor.pdf, it is described "The address generation unit is shifted one stage back in the pipeline to enable a single cycle load-use penalty".
I think this means the load can be performed in single cycle by pipelining.
The load pipe includes 2 stages and they would be the address generation and the L1 cache access.
In the same presentation material of ARM TechCon 2011, it is described "Single cycle load-use penalty in DPU".
Therefore, the load execution pipeline acts as the following.
Addr1 Cache1
Addr2 Cache2
Addr3 Cache3
Addr4 Cache4
Best regards,
Yasuhiko Koumoto.
