I set the frequency of the system counter to 20MHz: by set cntfrq_el0
dmesg:
arch_timer_of_init, rate 20000000
arch_timer: cp15 timer(s) running at 20.00MHz (phys).
but in dmesg, the time shows take 10 seconds to finish the boot,
but in fact, it is 3 mins which I count by my iphone.
does anyone can tell the reason?
since it is a arm board, I can't get the cpu freq though /proc/cpuinfo,
processor : 0BogoMIPS : 40.00Features : fp asimd evtstrm crc32 cpuidCPU implementer : 0x41CPU architecture: 8CPU variant : 0x0CPU part : 0xd03CPU revision : 4
Hardware : Rockchip RK3568 EVB1 DDR4 V10 BoardSerial : 0000000000000000
dmesg should count the Linux kernel time only? When start_kernel() is not executed, the cntfrq_el0 timer is not started?While you iphone time will calculate the time when you pressed the board Power On button? It takes much time for the Board Firmware to launch Linux kernel and this time may be ignored by you.
