Cortex M0+ delay routine without timers
Hello, I´m trying to implement a small assembly routine in a cortex M0+ in order to introduce a software controlled delay in microseconds. For performing this, i wrote this small while() routine:
      while (CyclesToDelay > 0)
         __no_operation();
         CyclesToDelay--;
So, knowing exactly what assembly instructions are executing, the clk clock frequency, and the number of clk cycles per instruction, I can calculate the CyclesToDelay value for a desired delay to introduce.
Assembly:
__no_operation();
0002 73F8 NOP
CyclesToDelay--;
0002 73FA LDR R1, [R0]
0002 73FC SUBS R1, R1, #1
0002 73FE STR R1, [R0]
0002 7400 LDR R1, [R0]
0002 7402 CMP R1, #0
0002 7404 BNE 0x000273F8
Instruction clk cycles according https://developer.arm.com/documentation/ddi0432/c/programmers-model/instruction-set-summary are:
NOP 1 clk cycles
LDR 2 clk cycles
SUBS 1 clk cycles
STR  2 clk cycles
LDR 2 clk cycles
CMP 1 clk cycles
BNE 3 clk cycles
Total clk cycles in this routine = 12 clk cycles,
CORE_CLK = 48mhz
Then,
1) 1 CORE_CLK cycle = 1 / 48 us
2) 12 CORE_CLK cycles = 12/48 us ( The number of microseconds one loop of this routine should delay)
Finally:
3)  CyclesToDelay *  (12/48) = delay_we_want_to_introduce(us)
     or
     CyclesToDelay = delay_we_want_to_inject(us) * 48 / 12
However, measuring the delays obtained with this method does not seem to be very accurate. I dont know if this is going to be deterministic or if this is totally possible in this Cortex M0+. Feedback would be appreciated. Many thanks.
  • I was about to say that you might use the DWT CYCCNT register, as I have done for CM3 and CM4.  Alas it appears to be missing from CM0/CM0plus.
    For what it's worth, here's the code for CM3/4, it might help you in some way.
    static void init(void);
    static uint32_t ticksPerMilli;
    /******************************** PUBLIC API *******************************/
    void delayMillis( size_t ms ) {
      if( ticksPerMilli == 0 ) {
    	init();
      // Reset the cycle counter and enable it, so it starts counting
      DWT->CYCCNT = 0;
      DWT->CTRL |= DWT_CTRL_CYCCNTENA_Msk;
      while( DWT->CYCCNT < (ms * ticksPerMilli) )
    void delaySeconds( size_t s ) {
      delayMillis( s * 1000 );
    static void init(void) {
      // Bit mask definitions (*_Msk) are from core_cmN.h
      // To use DWT, you have to set the Trace Enable bit in DEMCR...
      CoreDebug->DEMCR |= CoreDebug_DEMCR_TRCENA_Msk;
    	Trace DEMCR might not be writable from CPU (only debugger??).  If
    	that is true, the 'delay via cyccnt' can't be used on this MCU.
      if( !(CoreDebug->DEMCR & CoreDebug_DEMCR_TRCENA_Msk) )
    	assert(0);
      // CYCCNT might not be implemented. Assertion as above
      if( DWT->CTRL & DWT_CTRL_NOCYCCNT_Msk )
    	assert(0);
      // SystemCoreClock is a CMSIS Core-managed variable
      ticksPerMilli = SystemCoreClock / 1000;
  • Yes, it seems that this option its not avaliable on this MCU. Thanks anyway,, hehe
