Hello,I would like to know what is IO Coherency in ARM Cortex R5?
Thanks,
Surabhi
Hi Surabhi,
I think this refers to the Cortex-R5 Accelerator Coherency Port (ACP).
This is an AXI port where you can connect a peripheral. The ACP port will provide coherency between the CPUs and the peripheral. In the case of the Cortex-R5, the peripheral writes will invalidate cache lines from the CPUs caches.
See the ACP chapter in the Cortex-R5 Technical Reference Manual.
