STM32 F411RE SPI4 Pins Not Working
I am using F411RE Nucleo board to communicate with some other devices through SPI.
My code is based on SPI LL example SPI_TwoBoards_FullDuplex_DMA in package STM32Cube_FW_F4_V1.26.0.
The original code works well. However, my app needs more than one SPI; so I tried to change SPI1 to SPI4.
The DMA and SPI configurations are showed in below:
  * @brief This function configures the DMA Channels for SPI1
  * @note  This function is used to :
  *        -1- Enable DMA2 clock
  *        -2- Configure NVIC for DMA2 transfer complete/error interrupts
  *        -3- Configure the DMA2_Stream2 functional parameters
  *        -4- Configure the DMA2_Stream3 functional parameters
  *        -5- Enable DMA2 interrupts complete/error
  * @param   None
  * @retval  None
void Configure_DMA(void)
  /* DMA2 used for SPI1 Transmission
   * DMA2 used for SPI1 Reception
  /* (1) Enable the clock of DMA2 and DMA2 */
  LL_AHB1_GRP1_EnableClock(LL_AHB1_GRP1_PERIPH_DMA2);
 /* (2) Configure NVIC for DMA transfer complete/error interrupts */
#ifdef USE_SPI1
  NVIC_SetPriority(DMA2_Stream2_IRQn, 0);
  NVIC_EnableIRQ(DMA2_Stream2_IRQn);
  NVIC_SetPriority(DMA2_Stream3_IRQn, 0);
  NVIC_EnableIRQ(DMA2_Stream3_IRQn);
#endif
#ifdef USE_SPI4
  NVIC_SetPriority(DMA2_Stream0_IRQn, 0);
  NVIC_EnableIRQ(DMA2_Stream0_IRQn);
  NVIC_SetPriority(DMA2_Stream1_IRQn, 0);
  NVIC_EnableIRQ(DMA2_Stream1_IRQn);
#endif
  /* (3) Configure the DMA2_Stream2 functional parameters */
  LL_DMA_ConfigTransfer(DMA2,
		                SPI_RX_STREAM,
                        LL_DMA_DIRECTION_PERIPH_TO_MEMORY | LL_DMA_PRIORITY_HIGH | LL_DMA_MODE_NORMAL |
                        LL_DMA_PERIPH_NOINCREMENT | LL_DMA_MEMORY_INCREMENT |
                        LL_DMA_PDATAALIGN_BYTE | LL_DMA_MDATAALIGN_BYTE);
  LL_DMA_ConfigAddresses(DMA2,
		                 SPI_RX_STREAM,
                         LL_SPI_DMA_GetRegAddr(SPI), (uint32_t)aRxBuffer,
                         LL_DMA_GetDataTransferDirection(DMA2, SPI_RX_STREAM));
  LL_DMA_SetDataLength(DMA2, SPI_RX_STREAM, ubNbDataToReceive);
  LL_DMA_SetChannelSelection(DMA2, SPI_RX_STREAM, SPI_RX_CHANNEL);
  /* (4) Configure the DMA2_Stream3 functional parameters */
		                SPI_TX_STREAM,
                        LL_DMA_DIRECTION_MEMORY_TO_PERIPH | LL_DMA_PRIORITY_HIGH | LL_DMA_MODE_NORMAL |
  LL_DMA_ConfigAddresses(DMA2, SPI_TX_STREAM, (uint32_t)aTxBuffer, LL_SPI_DMA_GetRegAddr(SPI),
                         LL_DMA_GetDataTransferDirection(DMA2, SPI_TX_STREAM));
  LL_DMA_SetDataLength(DMA2, SPI_TX_STREAM, ubNbDataToTransmit);
  LL_DMA_SetChannelSelection(DMA2, SPI_TX_STREAM, SPI_TX_CHANNEL);
  /* (5) Enable DMA interrupts complete/error */
  LL_DMA_EnableIT_TC(DMA2, SPI_RX_STREAM);
  LL_DMA_EnableIT_TE(DMA2, SPI_RX_STREAM);
  LL_DMA_EnableIT_TC(DMA2, SPI_TX_STREAM);
  LL_DMA_EnableIT_TE(DMA2, SPI_TX_STREAM);
  * @brief This function configures SPI1.
  *        -1- Enables GPIO clock and configures the SPI1 pins.
  *        -2- Configure SPI1 functional parameters.
  * @note   Peripheral configuration is minimal configuration from reset values.
  *         Thus, some useless LL unitary functions calls below are provided as
  *         commented examples - setting is default configuration from reset.
  * @param  None
  * @retval None
void Configure_SPI(void)
  /* (1) Enables GPIO clock and configures the SPI1 pins ********************/
  /* Enable the peripheral clock of GPIOB */
  if(! LL_AHB1_GRP1_IsEnabledClock(LL_AHB1_GRP1_PERIPH_GPIOB)) {
	LL_AHB1_GRP1_EnableClock(LL_AHB1_GRP1_PERIPH_GPIOB);
  if(! LL_AHB1_GRP1_IsEnabledClock(LL_AHB1_GRP1_PERIPH_GPIOA)) {
	LL_AHB1_GRP1_EnableClock(LL_AHB1_GRP1_PERIPH_GPIOA);
#ifdef USE_SPI1
  /* Configure SCK Pin connected to pin 31 of CN10 connector */
  LL_GPIO_SetPinMode(GPIOB, SPI_CLK_PIN, LL_GPIO_MODE_ALTERNATE);
  LL_GPIO_SetAFPin_0_7(GPIOB, SPI_CLK_PIN, LL_GPIO_AF_5);
  LL_GPIO_SetPinSpeed(GPIOB, SPI_CLK_PIN, LL_GPIO_SPEED_FREQ_HIGH);
  LL_GPIO_SetPinPull(GPIOB, SPI_CLK_PIN, LL_GPIO_PULL_DOWN);
  /* Configure MISO Pin connected to pin 27 of CN10 connector */
  LL_GPIO_SetPinMode(GPIOB, SPI_MISO_PIN, LL_GPIO_MODE_ALTERNATE);
  LL_GPIO_SetAFPin_0_7(GPIOB, SPI_MISO_PIN, LL_GPIO_AF_5);
  LL_GPIO_SetPinSpeed(GPIOB, SPI_MISO_PIN, LL_GPIO_SPEED_FREQ_HIGH);
  LL_GPIO_SetPinPull(GPIOB, SPI_MISO_PIN, LL_GPIO_PULL_DOWN);
  /* Configure MOSI Pin connected to pin 29 of CN7 connector */
  LL_GPIO_SetPinMode(GPIOB, SPI_MOSI_PIN, LL_GPIO_MODE_ALTERNATE);
  LL_GPIO_SetAFPin_0_7(GPIOB, SPI_MOSI_PIN, LL_GPIO_AF_5);
  LL_GPIO_SetPinSpeed(GPIOB, SPI_MOSI_PIN, LL_GPIO_SPEED_FREQ_HIGH);
  LL_GPIO_SetPinPull(GPIOB, SPI_MOSI_PIN, LL_GPIO_PULL_DOWN);
  /* (2) Configure SPI1 functional parameters ********************************/
  LL_APB2_GRP1_EnableClock(LL_APB2_GRP1_PERIPH_SPI1);
#endif
#ifdef USE_SPI4
  /* Configure SCK Pin PB13 */
  LL_GPIO_SetAFPin_8_15(GPIOB, SPI_CLK_PIN, LL_GPIO_AF_6);
  /* Configure MISO Pin PA11 */
  LL_GPIO_SetPinMode(GPIOA, SPI_MISO_PIN, LL_GPIO_MODE_ALTERNATE);
  LL_GPIO_SetAFPin_8_15(GPIOA, SPI_MISO_PIN, LL_GPIO_AF_6);
  LL_GPIO_SetPinSpeed(GPIOA, SPI_MISO_PIN, LL_GPIO_SPEED_FREQ_HIGH);
  LL_GPIO_SetPinPull(GPIOA, SPI_MISO_PIN, LL_GPIO_PULL_DOWN);
  /* Configure MOSI Pin PA1 */
  LL_GPIO_SetPinMode(GPIOA, SPI_MOSI_PIN, LL_GPIO_MODE_ALTERNATE);
  LL_GPIO_SetAFPin_0_7(GPIOA, SPI_MOSI_PIN, LL_GPIO_AF_5);
  LL_GPIO_SetPinSpeed(GPIOA, SPI_MOSI_PIN, LL_GPIO_SPEED_FREQ_HIGH);
  LL_GPIO_SetPinPull(GPIOA, SPI_MOSI_PIN, LL_GPIO_PULL_DOWN);
  /* (2) Configure SPI4 functional parameters ********************************/
  LL_APB2_GRP1_EnableClock(LL_APB2_GRP1_PERIPH_SPI4);
#endif
  /* Configure SPI1 communication */
  LL_SPI_SetBaudRatePrescaler(SPI, LL_SPI_BAUDRATEPRESCALER_DIV8);
  LL_SPI_SetTransferDirection(SPI, LL_SPI_FULL_DUPLEX);
  LL_SPI_SetClockPhase(SPI, LL_SPI_PHASE_1EDGE);
  LL_SPI_SetClockPolarity(SPI, LL_SPI_POLARITY_LOW);
  /* Reset value is LL_SPI_MSB_FIRST */
  LL_SPI_SetTransferBitOrder(SPI, LL_SPI_MSB_FIRST);
  LL_SPI_SetDataWidth(SPI, LL_SPI_DATAWIDTH_8BIT);
  LL_SPI_SetNSSMode(SPI, LL_SPI_NSS_SOFT);
#ifdef MASTER_BOARD
  LL_SPI_SetMode(SPI, LL_SPI_MODE_MASTER);
#else
  /* Reset value is LL_SPI_MODE_SLAVE */
  //LL_SPI_SetMode(SPI, LL_SPI_MODE_SLAVE);
#endif /* MASTER_BOARD */
  /* Configure SPI1 DMA transfer interrupts */
  /* Enable DMA RX Interrupt */
  LL_SPI_EnableDMAReq_RX(SPI);
  /* Enable DMA TX Interrupt */
  LL_SPI_EnableDMAReq_TX(SPI);
Some of the macro definitions are showed here:
//#define USE_SPI1
#define USE_SPI4
#ifdef USE_SPI1
	#define   SPI                   SPI1
	#define   SPI_RX_STREAM        LL_DMA_STREAM_2
	#define   SPI_RX_CHANNEL       LL_DMA_CHANNEL_3
	#define   SPI_TX_STREAM        LL_DMA_STREAM_3
	#define   SPI_TX_CHANNEL       LL_DMA_CHANNEL_3
	#define   SPI_CLK_PIN        LL_GPIO_PIN_3
	#define   SPI_MOSI_PIN       LL_GPIO_PIN_5
	#define   SPI_MISO_PIN       LL_GPIO_PIN_4
#endif
#ifdef USE_SPI4
	#define   SPI                   SPI4
	#define   SPI_RX_STREAM        LL_DMA_STREAM_0
	#define   SPI_RX_CHANNEL       LL_DMA_CHANNEL_4
	#define   SPI_TX_STREAM        LL_DMA_STREAM_1
	#define   SPI_TX_CHANNEL       LL_DMA_CHANNEL_4
	#define   SPI_CLK_PIN        LL_GPIO_PIN_13
	#define   SPI_MOSI_PIN       LL_GPIO_PIN_1
	#define   SPI_MISO_PIN       LL_GPIO_PIN_11
#endif
The whole project works well when I enable SPI1, but does not work when SPI4 is enabled (SPI1 disabled). The problem is that I cannot see any signal on CLK, MISO, and MOSI pins.
