Cortex-R52 SPI interrupt routing to PEs not working
I try to configure GIC interrupt controller on a cortex R52 multicore setup to be able to receive SPI interrupts on all available cores.
Interrupt handling works fine as long as all interrupts are routed to core 0 (I assume routing to core 0 is the default).
Interrupt routing is done by setting GICD_IROUTER<n> registers of the source.
In GIC distributor ARE_S bit is set in GICD_CTLR register, so affinity routing is active for secure state.
Interrupts to be tested are triggered by directly writing to corresponding bit of GICD_ISPENDR<n> register.
When triggering interrupt source to be processed on core 1 pending flag in GIC Distributor is set, yet GIC CPU interface of core 1 does not show any pending interrupt source.
GICC_PMR of core 1 is set to allow all priorities.
Are there any other modules to check to see why interrupt is not routed correctly to the PE?
Thanks,
Lukas
