Hi all.
May I know how to set the stack size in linker file for Cortex-A72?
I use the below linker file but I cannot see the ".stack" section in map file.
STACKSIZE = DEFINED(STACKSIZE) ? STACKSIZE : 0x80000; HEAPSIZE = DEFINED(HEAPSIZE) ? HEAPSIZE : 0x80000; MEMORY { DDR4 : o = 0x80000, l = 0x40000000 /* 1GB external DDR */ } SECTIONS { .text : { KEEP(*(.text.boot)) *(.text .text.* .gnu.linkonce.t*) } > DDR4 .rodata : { *(.rodata .rodata.* .gnu.linkonce.r*) } > DDR4 PROVIDE(_data = .); .data : { *(.data .data.* .gnu.linkonce.d*) } > DDR4 .bss (NOLOAD) : { . = ALIGN(16); __bss_start = .; *(.bss .bss.*) *(COMMON) __bss_end = .; } > DDR4 .heap (NOLOAD): { /* The line below can be used to FILL the memory with a known value and * debug any stack overruns. For this to work, the specifier (NOLOAD) above * must be removed at the expense of an increase in the output binary size */ FILL(0xDEADBEEF) . = ALIGN(16); __end__ = .; end = __end__; /* The line below created to be compatible with Linaro's semihosting support */ __HeapBase = __end__; *(.heap*) . = . + HEAPSIZE; __HeapLimit = .; } > DDR4 /* .stack section doesn't contain any symbols. It is only * used for linker to calculate size of stack sections, and assign * values to stack symbols later */ .stack (NOLOAD): { /* The line below can be used to FILL the memory with a known value and * debug any stack overruns. For this to work, the specifier (NOLOAD) above * must be removed at the expense of an increase in the output binary size */ FILL(0xBAD0BAD0) . = ALIGN(16); __StackLimit = . ; *(.stack*) . = . + STACKSIZE; __StackTop = . ; /* The line below created to be compatible with Linaro's semihosting support */ __StackBase = . ; } > DDR4 PROVIDE(__stack = __StackTop); _end = .; /DISCARD/ : { *(.comment) *(.gnu*) *(.note*) *(.eh_frame*) } } __bss_size = (__bss_end - __bss_start)>>3;
Thanks a lot.
