Still more stupid questions on Cortex-A7 instruction set
I've beem constructing a list of Cortex-A7 ARM-instructions, and there are some questions I haven't found
an answer to in ARMv7-A/R ARM Issue C.
How is this special?
LDRD<c>_<Rt>,_<Rt2>,_<label>_LDRD<c>_<Rt>,_<Rt2>,_[PC,_#-0]_Special_caseA1A8.8.73
Under which sub-chapter of A4 this fits best?
MOVW<c>_<Rd>,_#<imm12>A2A8.8.102
How about this:
VDIV<c>.F64_<Dd>,_<Dn>,_<Dm>_VDIV<c>.F32_<Sd>,_<Sn>,_<Sm>T1/A1
A8.8.312
About these (what's the Rt's role) I already asked in another thread.
PUSH<c>_<registers>,_<Rt>A2A8.8.133
POP<c>_<registers>,_<Rt>A2A8.8.132
These are the sub-chapters:
branches
Data-processing instructions
    Standard data-processing instructions.
    Shift instructions on page A4-167.
    Multiply instructions on page A4-167.
    Saturating instructions on page A4-169.
    Saturating addition and subtraction instructions on page A4-169.
    Packing and unpacking instructions on page A4-170.
    Parallel addition and subtraction instructions on page A4-171.
    Divide instructions on page A4-172.
    Miscellaneous data-processing instructions on page A4-173.
Status register access instructions
Load/store instructions
Load/store multiple instructions
Miscellaneous instructions
Exception-related instructions
Coprocessor instructions
Advanced SIMD and Floating-point load/store instructions
    Extension register load/store instructions
    Element and structure load/store instructions
Advanced SIMD and Floating-point register transfer instructions
Advanced SIMD data-processing instructions
    Advanced SIMD parallel addition and subtraction
    Bitwise Advanced SIMD data-processing instructions
    Advanced SIMD comparison instructions
    Advanced SIMD shift instructions
    Advanced SIMD multiply instructions
    Miscellaneous Advanced SIMD data-processing instructions
Floating-point data-processing instructions
  • Hello,
    LDRD<c>_<Rt>,_<Rt2>,_<label>_LDRD<c>_<Rt>,_<Rt2>,_[PC,_#-0]_Special_case A1 A8.8.73
    In ARM case,
    LDRD<c> Rt, Rt2, <label>
    is the same as
    LDRD<c> Rt, <label>.
    Rt should be the even number register. Also, Rt2 should be R(t+1).
    In Thumb case,
    Rt and Rt2 can be taken as  arbitrary registers.
    I don't know why
    LDRD<c> Rt. Rt2, [PC,#-0]
    is mentioned.
    Its function is the smae as
    LDRD<c> Rt, Rt2, [PC, #0]
    but the encoding is different because 'U' bit differs.
    I don't know why the imm=0 case is specially mentioned, either.
    MOVW<c>_<Rd>,_#<imm12> A2 A8.8.102
    This is the instruction to put #imm16 into Rd[15:0].
    This is used by combining with MOVT to put 32 bit immediate into the register.
    I am sorry but I cannot understand what you want to ask.
    How about this:
    VDIV<c>.F64_<Dd>,_<Dn>,_<Dm>_VDIV<c>.F32_<Sd>,_<Sn>,_<Sm> T1/A1
    A8.8.312
    This is the normal floating point division instruction.
    In Thumb case, F64 is only support by Cortex-M7.
    PUSH<c>_<registers>,_<Rt> A2 A8.8.133
    POP<c>_<registers>,_<Rt> A2 A8.8.132
    These are the instructions to push or pop of only one register (i.e. Rt).
    It is the same as
    STR<c> Rt, [SP,#-4]!
    for PUSH case.
    Also it the same as
    LDR<c>  Rt, [SP], #4
    for POP case.
    I guess that these instructions are faster executed than the push or pop of several registers,
    e.g. STMDB<c> SP!, {Rt} or LDMIA<c> SP!, {Rt}.
    Best regards,
    Yasuhiko Koumoto.
  • Thanks for explaining.
    The reason I'm asking is that I'm trying to write a gdb stub, and finding out the next instruction for single stepping requires instruction decoding (to a point), so I want to figure out how to organize the decoding in a reasonable way.
    I've already found that there are aliases in the document treated as "native" instructions and some instructions "turn" into other instructions if a register is PC or if immediate value is zero and the like.
    Like shifted register MOV or RRX.
    (Darn, I seem to have forgotten to mark this thread as a question.)
