Hey, I am using Cortex M1 soft core processor on Arty A7 100T using Vivado 2020.1 and successfully generated bitstream for simple AXI-Uartlite project and exported hardware xsa file, but when i tried to create a Application Project for the same using xsa file in Vitis 2020.1 the platform is getting created but the basic c/c++ application project creation is giving error as "Failed to call GENERATE_APP". Below is the Vitis log file for that error.
Can someone help in debugging this error?
13:51:28 DEBUG : Registering SDKStatusHandler to handle trace exceptions.13:51:28 DEBUG : Registered the core plugin as the backup plugin for storing repository paths.13:51:28 INFO : Launching XSCT server: xsct.bat -n -interactive D:\FPGA_Projects\Workspace\temp_xsdb_launch_script.tcl13:51:28 INFO : XSCT server has started successfully.13:51:28 INFO : Registering command handlers for Vitis TCF services13:51:29 INFO : plnx-install-location is set to ''13:51:29 INFO : Successfully done setting XSCT server connection channel 13:51:29 INFO : Successfully done query RDI_DATADIR 13:51:29 INFO : Successfully done setting workspace for the tool. 13:51:29 INFO : Restoring global repository preferences: C:\Users\vybha\Documents\AT472-BU-98000-r0p1-00rel0\vivado\Arm_sw_repository13:51:31 INFO : Platform repository initialization has completed.13:52:35 INFO : Result from executing command 'getProjects': Microblaze_uart_wrapper;arty_uart1_wrapper;arty_uart_wrapper;arty_uart_wrapper_1;arty_uart_wrapper_2;cortex_m1_uart_wrapper;design_1_wrapper;mblz_uart_gpio_wrapper;mblz_uart_gpio_wrapper_1;mblz_uart_gpio_wrapper_2;zynq_uart_wrapper13:52:35 INFO : Result from executing command 'getPlatforms': Microblaze_uart_wrapper|D:/FPGA_Projects/Workspace/Microblaze_uart_wrapper/export/Microblaze_uart_wrapper/Microblaze_uart_wrapper.xpfm;arty_uart1_wrapper|D:/FPGA_Projects/Workspace/arty_uart1_wrapper/export/arty_uart1_wrapper/arty_uart1_wrapper.xpfm;arty_uart_wrapper_1|D:/FPGA_Projects/Workspace/arty_uart_wrapper_1/export/arty_uart_wrapper_1/arty_uart_wrapper_1.xpfm;arty_uart_wrapper_2|D:/FPGA_Projects/Workspace/arty_uart_wrapper_2/export/arty_uart_wrapper_2/arty_uart_wrapper_2.xpfm;arty_uart_wrapper|D:/FPGA_Projects/Workspace/arty_uart_wrapper/export/arty_uart_wrapper/arty_uart_wrapper.xpfm;design_1_wrapper|D:/FPGA_Projects/Workspace/design_1_wrapper/export/design_1_wrapper/design_1_wrapper.xpfm;mblz_uart_gpio_wrapper_1|D:/FPGA_Projects/Workspace/mblz_uart_gpio_wrapper_1/export/mblz_uart_gpio_wrapper_1/mblz_uart_gpio_wrapper_1.xpfm;mblz_uart_gpio_wrapper_2|D:/FPGA_Projects/Workspace/mblz_uart_gpio_wrapper_2/export/mblz_uart_gpio_wrapper_2/mblz_uart_gpio_wrapper_2.xpfm;mblz_uart_gpio_wrapper|D:/FPGA_Projects/Workspace/mblz_uart_gpio_wrapper/export/mblz_uart_gpio_wrapper/mblz_uart_gpio_wrapper.xpfm;zynq_uart_wrapper|D:/FPGA_Projects/Workspace/zynq_uart_wrapper/export/zynq_uart_wrapper/zynq_uart_wrapper.xpfm13:52:35 INFO : Platform 'cortex_m1_uart_wrapper' is added to custom repositories.13:52:36 ERROR : Failed to call GENERATE_APP Reason: ERROR: [Common 17-39] 'hsi::generate_app' failed due to earlier errors.
13:52:36 ERROR : java.lang.RuntimeException: Failed to call GENERATE_APP Reason: ERROR: [Common 17-39] 'hsi::generate_app' failed due to earlier errors.
at com.xilinx.sdk.xsdb.XsdbCommandUtils.handleResult(XsdbCommandUtils.java:387) at com.xilinx.sdk.xsdb.XsdbCommandUtils.executeAndRespond(XsdbCommandUtils.java:325) at com.xilinx.sdx.sdk.core.gen.CTemplateGen.generate(CTemplateGen.java:105) at com.xilinx.sdx.sdk.core.gen.CppTemplateGen.generate(CppTemplateGen.java:53) at com.xilinx.sdx.sdk.core.gen.StandaloneProjectHandler.createCoreApp(StandaloneProjectHandler.java:93) at com.xilinx.sdx.sdk.core.gen.AppCreationHandler.createApplication(AppCreationHandler.java:79) at com.xilinx.sdx.sdk.core.gen.AppCreationHandler.execute(AppCreationHandler.java:69)13:52:36 ERROR : Failed to create application projectorg.eclipse.core.runtime.CoreException: Failed to call GENERATE_APP Reason: ERROR: [Common 17-39] 'hsi::generate_app' failed due to earlier errors.
at com.xilinx.sdx.sdk.core.gen.StandaloneProjectHandler.createCoreApp(StandaloneProjectHandler.java:150) at com.xilinx.sdx.sdk.core.gen.AppCreationHandler.createApplication(AppCreationHandler.java:79) at com.xilinx.sdx.sdk.core.gen.AppCreationHandler.execute(AppCreationHandler.java:69) at com.xilinx.sdx.sdk.core.SdkAppCreationHandler.executeInternal(SdkAppCreationHandler.java:75) at com.xilinx.sdx.sdk.core.SdkAppCreationHandler.lambda$1(SdkAppCreationHandler.java:67) at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2289) at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2311)13:52:37 ERROR : An unexpected exception occurred in the module 'updating project references'13:52:37 ERROR : An unexpected exception occurred in the module 'updating project references'13:52:37 ERROR : An unexpected exception occurred in the module 'updating project references'13:52:37 ERROR : An unexpected exception occurred in the module 'updating project references'13:52:37 ERROR : An unexpected exception occurred in the module 'updating project references'13:52:37 ERROR : An unexpected exception occurred in the module 'updating project references'13:52:37 ERROR : An unexpected exception occurred in the module 'updating project references'13:52:37 ERROR : An unexpected exception occurred in the module 'updating project references'13:52:37 ERROR : An unexpected exception occurred in the module 'updating project references'13:52:37 ERROR : An unexpected exception occurred in the module 'updating project references'13:52:37 ERROR : An unexpected exception occurred in the module 'updating project references'13:52:37 ERROR : An unexpected exception occurred in the module 'updating project references'13:52:37 ERROR : An unexpected exception occurred in the module 'updating project references'13:52:37 ERROR : An unexpected exception occurred in the module 'updating project references'13:52:37 ERROR : An unexpected exception occurred in the module 'updating project references'13:52:37 ERROR : An unexpected exception occurred in the module 'updating project references'13:52:37 ERROR : An unexpected exception occurred in the module 'updating project references'13:52:37 ERROR : An unexpected exception occurred in the module 'updating project references'13:52:37 ERROR : An unexpected exception occurred in the module 'updating project references'13:52:37 ERROR : An unexpected exception occurred in the module 'updating project references'13:52:37 ERROR : An unexpected exception occurred in the module 'updating project references'
