Cycle counter: on which ARM will the code successfully run?
Former Member
Former Member
On a Raspberry Pi 3b, which is ARM Cortex-A5 processor, ARMv7 architecture, I am reading the cycle counter registers from the PMU (Performance Monitor Unit):
uint32_t cycle_counter_read (void)
  uint32_t cc = 0;
  __asm__ volatile ("mrc p15, 0, %0, c9, c13, 0":"=r" (cc));
  return cc;
I'd like to understand on which ARM processors will this code run successfully, other than the one in Raspberry Pi 3B.
Which ARM info is important for this:
  • processor name (Cortex A5 only?)
  • architecture (ARMv7 only?)
  • aarch32 and/or aarch64?
  • the combination of the above?
  • something else?
Currently I have included this code only for ARMv7:
#if defined(PLATFORM_ARMV7)
    cycle_counter_read();
#endif
Thanks.
0
