Bus error while executing ARMv8 TLB instruction
I am facing "Bus error on memory operation" while executing below instruction while invalidating and flushing the TLB.
I am not able to understand what is the reason for "Bus error" as it is a TLB operation instruction ?  Also what Bus error signify ?
Also similar error is coming while I try to invalidate instruction cache.
/* Invalidate and flush the TLB */
   "tlbi   alle2 \n\t"    \
Thanks,
  • Where are you seeing "Bus error on memory operation", in the debugger?
    Without know the tool you're using, I suspect it means that the memory system returned an error.  When a memory access is made by the core it if first checked against the core's MMU, and then presented to the memory system.  Which means the MMU might fault, or if it passes those checks, the memory system (bus) might fault it.
    That you would see this immediately after a TLBI isn't necessarily surprising.  Changes to translation tables are not guaranteed to take affect until after an appropriate TLB invalidate.  What I suspect is happening is that you stepped the TLBI, then the debugger refreshed the various windows you had open.  These refreshes would be using the updated view of the translations - which in this case is leading to a bus fault.
    So to me, the most likely answer is that you (perhaps unintentionally) are performing an access that the memory system can't handle.  Which is in some way connected to the change the code is making to the translation tables.  Possible reasons could be:
    - The translation tables have mapped in a physical address that doesn't exist
    - The debugger is performing an access type the address doesn't support (e.g. 64-bit read from a peripheral that only supports byte reads)
  • Hi,
    Yes I see it in the debugger once I set up the translation table and try to invalidate the current TLB in order to make sure that my settings are flushed and taking effect.
    I wanted to debug my MMU setup code so I step through the code and I see this error when I invalidate TLB.
    I am not sure though if this error is coming in case my table settings are wrong ?
    Thanks,
  • Hi Martin,
    I found the cause of the Bus error which is the wrong value of TCR_T0SZ in TCR_EL2 register.
    I am not very clear after reading the ARMv8 spec as how to choose TCR_T0SZ value ?
    Can any one please explain based on Levels and granular size (e.g. 4K, 16K and 64K) what should be the value for TCR_T0SZ ?
    Thanks,
  • TCR_ELn.T0SZ sets the size of the virtual address space described by the tables pointed at by TTBR0_ELn.  That is, the address space will go from 0x0000,0000,0000,0000 to X.  The maximum size of the address space is 48 bits, which would make X=0x0000,FFFF,FFFF,FFFF.
    The way it is encoded is:  Size of Address Space (in bits) = 64 - T0SZ
    Examples:
    48-bit address space (X=0x0000,FFFF,FFFF,FFFF): T0SZ = 16
    40-bit address space (X=0x0000,00FF,FFFF,FFFF): T0SZ = 24
    32-bit address space (X=0x0000,0000,FFFF,FFFF): T0SZ = 32
    The size of the address and the granule size together set the starting level of translation.  Each level of translation describes different sized blocks of address space, the sizes varying based on the granule selected.  For example, for 4K granule:
    Level 0: Each entry represents 512GB of address space
    Level 1: Each entry represents 1GB of address space
    Level 2: Each entry represents 2MB of address space
    Level 3: Each entry represents 4KB of address space
    So if, using T0SZ, you shrink the total address space to 512GB or less - you don't need a L0 table.  Starting level would L1.
    Similarly, if you shrink the address to 1GB or below, you don't need a L1 table.  Starting level would L2.
    The same theory applies the other granules, it's just the sizes are different.
    The ARM ARM gives tables that tell you the starting level of translation for different address sizes and granules: Table D4-10, Table D4-13 and Table D4-16.
    NOTE: There is an extra setting for 2nd stage translation, but as you referred to TTBR0_EL2 (which controls stage 1) I haven't gone into that.
  • Forgot to mention....
    This begs the question of what happens if you set T0SZ to 0, which would make the address space larger than the allowed maximum.  From the ARM ARM:
    The minimum TxSZ value is 16. If TxSZ is programmed to a value smaller than 16 then it is IMPLEMENTATION DEFINED whether:
    • The implementation behaves as if the field were programmed to 16 for all purposes other than reading back the value of the field.
    • Any use of the TxSZ value generates a stage 1 Level 0 Translation fault.
