I write the code as following to evaluate the expression n = n / 2
asrs r0, r0, #1
But, I found the GCC will translate the expression n = n / 2 into the following instruction
lsrs r1, r0, #31
adds r0, r1, r0
Why does it need to add the sign bit?
Greetings,,
did you defined (n) to be unsigned ?
Regards,,
Hello Chi-wai,
it is because to compensate shift error in the negative integer case.
For example, we think of -3 (i.e. 0xFFFFFFFD).
If is it right shifted by 1, the result is 0xFFFFFFFE (-2). Although we expect it as 0xFFFFFFFF (-1).
Therefore by adding the sign bit to 0xFFFFFFFD, making 0xFFFFFFFE.
By right shifting 0xFFFFFFFE by 1, resulting to 0xFFFFFFFF. It will match with our expectation.
Best regards,
Yasuhiko Koumoto.
It looks like you're working with Cortex-M0.
On other ARM architectures, including Cortex-M3 and later, I think you can use the following code:
add r0,r0,r0,lsr#31 /* r0 = r0 + (r0 >> 31) */
asrs r0,r0,#1
Size will still be 6 bytes, but it should use one clock cycle less; eg. 2 clock cycles in total.
Exactly jens
