Hi All,I am not sure if this is the perfect place to ask this question or not.But as we are stuck at a point since long, I decided to post it here.Please read the post and suggest me if I have to post this question at some other forum.
We are trying to boot Linux kernel-5.10.39 with U-Boot 2021.10-rc2 on Veloce emulator, with ARM Cortex-A78 core in it.
Below are the information which we have followed:
Hardware details: - an ARM Cortex-A78 core - an interconnect - boot SRAM - an NS16550-A UART -> to access this hardware, we use Veloce emulator.
Software details: -> We place bootcode, uboot.bin, kernel image and device tree files at a predefined memory location of RAM as shown in memory map, below. -> We are following this link ( https://linux-sunxi.org/U-Boot ) for u-boot configuration. Below are the commands, which we executed for our setup: - prepared ARM trusted firmware for Juno platform (as Juno is the best match for our system) using below command: # make CROSS_COMPILE=aarch64-linux-gnu- PLAT=juno DEBUG=1 bl31 (We chose juno here, as both juno and our core uses ARMv8-A architecture and supports AArch64.) - used vexpress_aemv8a_juno_defconfig, with below command: # make CROSS_COMPILE=aarch64-linux-gnu- BL31=<path_to_arm-trusted-firmware>/build/sun50i_a64/debug/bl31.bin vexpress_aemv8a_juno_defconfig - modified CONFIG_SYS_TEXT_BASE, with a memory address where we place uboot.bin in SRAM - changed UART configurations as per our NS16550-A UART -> Kernel is compiled with "relocatable kernel = NO" option with 4KB page size and 39bit VA_BITs
Memory Map: 0x000000000000 to 0x000000FFFFFF => memory Zone 1 => bootcode is placed at 0x00 location (ARM Core Reset address) 0x974400000000 to 0x9747FFFFFFFF => memory Zone 2 => U-Boot Image is placed at 0x974400000000 (size 650KB) => configured U-Boot RAM top at 0x974408000000 (128MB) => Kernel Image is placed at 0x974409000000 (size 9.5MB) 0x9A48AA140000 to 0x9A48AA17FFFF => memory Zone 3 => Device tree is placed at 0x9a48aa140000 0x82884C000000 to 0x82884c0FFFFF => memory Zone 4 => UART FIFO address is 0x82884c000000 Execution flow: 1. A78 core comes out of reset 2. executes a boot code present at its reset location - The boot code configures our interconnect and unblocks the SRAM memory zones according to the configurations - it allocates stack area and perform other necessary tasks to configure the A78 core registers - then branches to the memory location where u-boot.bin is already present NOTE: The A78 core is in EL3 after reset and the boot code doesn't change it 3. start executing u-boot.bin - modified vexpress_aemv8a.h file according to our SRAM addresses - modified some other files as required in runtime 4. starts executing kernel code Problem: - control reaches to execute start_kernel() in ./linux-5.10.39/init/main.c file - in this start_kernel function the execution gets stuck while executing set_task_stack_end_magic() function - to be more specific, when the code tries to run "*stackend = STACK_END_MAGIC;" line of set_task_stack_end_magic() function, it generates an curr_el_spx_sync exception
Our observations: - the "*stackend = STACK_END_MAGIC;" is trying to store STACK_END_MAGIC value on a virtual address - if we replace the virtual address (which has upper 25bits set) with any other physical address (with upper 25bits clear), the execution gets stuck in next function smp_setup_processor_id() We need help here, to resolve this issue.Can any one help us out here ?Please feel free to inform me, if I am unclear to you at any point or you need more information.
Maunik Patel said: NOTE: The A78 core is in EL3 after reset and the boot code doesn't change it
I am pretty sure, Linux will not run in EL3, you (u-boot) need to switch to EL1.
Or do it before entering u-boot.
Booting Linux at EL1 is fine. Booting at EL2 would enable support for virtualization and might be even closer to "real life".
See arm64/booting.rst for the details of the ABI.
That's true, Linux will not boot in EL3.I confirmed that EL drops to EL2 by the u-boot itself.So kernel execution is starting in EL2.Can it cause the issue, which we are facing ?
You need to check ESR_ELx register to find out the reason of the exception. I suspect that the MMU table was corrupted.
Any reason why you compiled kernel with "relocatable kernel = NO"?
