where can I find the detailed explanation of ARM PMU events?
Two questions:
1. Where can I find the detailed explanation of ARM PMU events?
2. How to know the stall cycles for e.g. icache miss etc.?
Thanks.
  • Hello alexamy,
    The PMU is an ARM Architectural Extension so you will have detailed explanations in the ARM Architecture Reference Manual; in particular, Chapter D5 "The Performance Monitors Extension" in the ARM v8-A ARM. Section D5.10 describes some of the architecturally-defined events, of which event 0x001 (L1I_CACHE_REFILL) can be used to count level 1 instruction cache refills.
    Normally, you may find implementation-specific information about PMUs in the Technical Reference Manual for a given processor, for example for the Cortex-A57 PMU.
    -Duberly
  • Hi dmazuelos,
    Thanks for your reply.
    As to the second question: how to know the stall cycles for e.g. icache miss?  Take event 0x001 (Level 1 instruction cache refill) as example, can I know the percentage of event 0x001 within one time duration (for example 5s)? Or can I know how many cycles are occupied by event 0x001 with that time duration?
    Thanks.
    -Alex
  • Hi Alex,
    the PMU measures the number of every event. So you cannot get the event cycles but get event percentage.
    Best regards,
    Yasuhiko Koumoto.
