Cortex-M3 System bus registration of instruction requests
I am university student at my final year and I am doing research on Cortex-M3.
One thing that I found problematic was system bus registration of instruction and vector fetch requests.
Only available source of information I found was this paragraph in documentation, but it wasn't descriptive enough.
I am not sure what is registered and when. Is it address, response or maybe both of them?
I would be grateful if somebody could point me to more descriptive material.
  • Yes. Essentially it provides a clean timing interface by registering this interface. So there is an additional cycle by including the register in the interface pathway.  So fetching vectors /instructions incurs an additional pathway. For the CM3 the recommendation is to have code via the I-code interface for this reason. This was done to ensure implementation on the backend is easier to meet timing.
  • Thank you for response.
    Do you know how exactly it works?
    > What is registered and when. Is it address, response or maybe both of them?
