Parallel Flash Memory to Integrate with CMSDK example
Hello Guys
I am trying to add an external parallel flash Memory with Cortex-M0.  I see that  cmsdk_ahb_to_extmem16.v file uses Lower byte enable and upper byte enable pin to select the bytes in the Memory. I was trying to find the commercially available external parallel flash Memory to integrate with the processor. But could not get. Does anyone know about such flash memory?
I am sharing the interfaces of the file. If you notice the output wires you can get it. Please help me find the appropriate memory. The block diagram can be found here.https://developer.arm.com/docs/ddi0479/c/basic-ahb-lite-components/ahb-to-external-sram-interface .
Fullscreen
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
// Port Definitions
input wire HCLK, // Clock
input wire HRESETn, // Reset
input wire HSEL, // Device select
input wire [AW-1:0] HADDR, // Address
input wire [1:0] HTRANS, // Transfer control
input wire [2:0] HSIZE, // Transfer size
input wire HWRITE, // Write control
input wire [31:0] HWDATA, // Write data
input wire HREADY, // Transfer phase done
output wire HREADYOUT, // Device ready
output wire [31:0] HRDATA, // Read data output
output wire HRESP, // Device response (always OKAY)
// Static configuration
input wire [2:0] CFGREADCYCLE, // Read cycles
input wire [2:0] CFGWRITECYCLE, // Write cycles
input wire [2:0] CFGTURNAROUNDCYCLE, // Turn around cycles
input wire CFGSIZE, // port size (0=8-bit, 1=16-bit)
XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
0
