compiler optimization options for ARMv8 GCC compiler on ARM cortex a53 (bare metal application)
I am using ARMv8 GCC compiler(aarch64-none-elf-gcc) for my bare metal application on ARM cortex a53. I am using neon intrinsics with plain C in my code so I would like to ensure to use all optimization option available for this compiler.
I tried -mfpu = neon but compiler is not recognizing it. So, what are the possible optimization option available for my application setting. I am using Xilinx SDK  IDE for my application.
  • Search for "gcc aarch64 options", "neon armv8", "neon aarch64" and "ARM C Language Extensions 2.0".
  • Hi,
    Thanks for your input. I used some of the options but my compiler is not recognizing some options. For example, I used
    5557.optimizationOption.pdf
    make all
    'Building file: ../ti_src/rl_controller.c'
    'Invoking: ARM v8 gcc compiler'
    aarch64-none-elf-gcc -DZF_B2 -Wall -O3 -mfpu=neon-fp-armv8 -g3 -I"D:\docs\sw_backup-5-03-2020\app\inc" -I"D:\docs\sw_backup-5-03-2020\app\src\architecture" -I"C:\Xilinx\SDK\2019.1\data\embeddedsw\lib\bsp\standalone_v6_8\src\arm\cortexa53\64bit" -I"C:\Xilinx\SDK\2019.1\gnu\aarch64\nt\aarch64-none\aarch64-none-elf\include" -I"D:\docs\sw_backup-5-03-2020\zf_b-2_freertos_bsp\psu_cortexa53_0\include" -I"D:\docs\sw_backup-5-03-2020\app\testdata" -I../../zf_b-2_freertos_bsp/psu_cortexa53_0/include -c -fmessage-length=0 -MT"ti_src/rl_controller.o" -MMD -MP -MF"ti_src/rl_controller.d" -MT"ti_src/rl_controller.o" -o "ti_src/rl_controller.o" "../ti_src/rl_controller.c"
    aarch64-none-elf-gcc: error: unrecognized command line option '-mfpu=neon-fp-armv8'
    make: *** [ti_src/subdir.mk:32: ti_src/rl_controller.o] Error 1
    If I use -mfpu=vFPv4 or -mfloat-abi=hard, compiler still not recognizing it. I would like to use floating point ABI for hardware linkages.
    I set the Xilinx SDK with the following settings:
  • NEON is active by default. Same for FPU.
    You can tell gcc not to use FPU registers: -mgeneral-regs-only
  • Thanks for the input.  But what about floating-point ABI? How can I enable it to -mfloat-abi=hard because compiler is not recognizing it. I would highly appreciate if you can comment on this.
  • If you look at the assembly, you will see: It is on by default.
    int res(float a, float b)
      return (int)(a+b);
    Compile with -O
           .arch armv8-a
            .file   "calling.c"
            .text
            .align  2
            .global res
            .type   res, %function
    res:
            fadd    s0, s0, s1
            fcvtzs  w0, s0
            ret
            .size   res, .-res
  • Hello Bastian. This compilation argument is not recognized by the arm-none-eabi-gcc compiler for Cortex A9 (armv7-a). Is it only supported for ARMv8?
    By the way if the compiler prevents accesses to FPU registers, does that conflict with compiling with mfpu=vfpv3 and mfloat-abi=hard arguments?
    Regards,
    Florian
  • gcc 9.1.0
    Guess that answers your question:
    arm-none-eabi-gcc -mgeneral-regs-only -march=armv7-a -mfpu=vfpv3 -S float.c -mfloat-abi=hard
    float.c: In function 'res':
    float.c:1:5: error: argument of type 'float' not permitted with -mgeneral-regs-only
        1 | int res(float a, float b)
  • btw: *gcc -target-help lists all options.
  • Hello;
    Thank you a lot for your inputs. Actually I did not have this option, that's why I asked.
    I used gcc 5.4.1, gcc 7.2 and gcc 8.2.0, but the -mgeneral-regs-only never appears. Maybe it's only available for gcc 9.1.0 and above
