I am trying to program an F407VG manually without using CubeMX and using registers. Could someone please help me get the SPI running? When I look on an oscilloscope, the Slave/Chip select goes low and high correctly but I am writing data to SPI1 DR and I don't see anything on MOSI or SCLK. What have I done wrong? C code below:
/* ENABLING AND CONFIGURING CLOCKS */ RCC->AHB1ENR |= (1<<0); //GPIO config RCC->AHB1ENR |= (1<<4); RCC->APB2ENR |= (1<<12); // SPI_1 Enabled RCC->CR |= (1<<0); // Enable the 16 MHz HSI clock RCC->PLLCFGR |= (0<<22); // Set HSI as source RCC->PLLCFGR |= (1<<1) | (0<<0); // Adjust to use PLL // Set the divider PLL_M to 16 to get 1 MHz since HSI is 16 MHz RCC->PLLCFGR |= (0<<0) | (0<<1) | (0<<2) | (0<<3) | (1<<4) | (0<<5); // SET PLL_N as 288 RCC->PLLCFGR |= (0<<6) | (0<<7) | (0<<8) | (0<<9) | (0<<10) | (1<<11) | (0<<12) | (0<<13) | (1<<14); // Set PLL_P as 4 to get 72 MHz RCC->PLLCFGR |= (1<<16) | (0<<17); // Set APB2 divider to 2 to get 36 MHz RCC->PLLCFGR |= (1<<15) | (0<<14) | (0<<13); /*GPIO PINS*/ //Set PE5 as output for CS, push pull, no pull up/down GPIOE->MODER |= (1<<10); GPIOE->OTYPER |= (0<<5); GPIOE->OSPEEDR |= (1<<10); GPIOE->PUPDR |= (00<<10); GPIOE->BSRR |= (1<<5); // Set PA5 as SCLK using AF5 GPIOA->MODER |= (1<<11); GPIOA->OTYPER |= (0<<5); GPIOA->OSPEEDR |= (1<<10); GPIOA->PUPDR |= (1<<10); GPIOA->AFR[0] |= (1<<22) | (1<<20); // Set PA6 as MISO using AF5 GPIOA->MODER |= (1<<13); GPIOA->OTYPER |= (0<<6); GPIOA->OSPEEDR |= (1<<13); GPIOA->PUPDR |= (1<<12); GPIOA->AFR[0] |= (1<<24) | (1<<26); // Set PA7 as MOSI using AF5 GPIOA->MODER |= (1<<15); GPIOA->OTYPER |= (0<<7); GPIOA->OSPEEDR |= (1<<15); GPIOA->PUPDR |= (1<<14); GPIOA->AFR[0] |= (1<<28) | (1<<30); /* Configure SPI */ /* SPI is set as Master Mode Direction 2 Lines 8-Bit data size Clock polarity low Clock phase 1 Edge Baudrate prescalre of 32 Send the MSB first CRC disabled Software set NSS/CS */ SPI1->CR1 |= (0<<15) | (1<<14) | (0<<13) | (0<<11) | ... (0<<10) | (1<<9) | (0<<7) | (1<<6) | (1<<5) | (0<<4) | ... (0<<3) | (1<<2) | (0<<1) | (0<<0);
When running the code I set the CS pin to low and then write random data to the SPI1 DR like this:GPIOE->BSRR |= (0<<5);Delay by 10000SPI1->DR |= (1<<7) | (1<<2);Delay by 50SPI1->DR |= (0<<7) | (0<<2);Delay by 10000GPIOE->BSRR |= (1<<5);The delay is just a simple counter function. So in summary, I am configuring the HSI to be a source for PLL and then setting the division and multiplication factors such that the output frequency to APB/AHB is 72MHz. SPI1 is on APB2 so after dividing 72MHz by a prescaler of 2, I get 36 MHz as the clock frequency for SPI1 since I have read that SPI1 should be around 36 MHz. I have been through the code and registers again but I cannot find my error. Thank you for your help.
Wrong forum. Try an STM32 forum instead.
42Bastian Schick said:Wrong forum
Indeed - nothing to do with ARM.
onemorething: Nobody on any forum is going to want to plough through all those Magic Numbers!
Do yourself - and all other readers - a favour and use use the bit names!
