Hiii guys anyone know how to configure 2515 CAN with rpi3 board and i need a example code........please help frnds
Hi Tejadeep are you still looking for an answer to this question?
This PiCAN2 board provides Controller Area Network (CAN) Bus capabilities for the Raspberry Pi. It uses the Microchip MCP2515 CAN controller with MCP2551 CAN . There is an easy-to-install SocketCAN driver.
myprepaidcenter login
The Raspberry PI doesn't natively support CAN. .The Broadcom SoCs (System on a Chip) used by the Raspberry PI doesn't include a CAN controller. The Linux kernel supports CAN and includes Socket CAN drivers for the Microchip MCP2515 Stand-alone CAN Controller with SPI Interface !
PiCAN 2 User Guide. This PiCAN2 board provides Controller Area Network (CAN) Bus capabilities for the Raspberry Pi. It uses the Microchip MCP2515 CAN ...
MCDVOICE
This frequency can change between modules, and is commonly either 16 or 8 MHz. My MCP2515 CAN Bus module board has a 8MHz on-board crystal and hence, I set the above line to 8000000.
It uses the Microchip MCP2515 CAN controller with MCP2551 CAN . There is an easy-to-install socketcan driver.
MyAARPMedicare
