Problem
Once in a blue moon (every ~500 hours of run time, non-deterministic) I am getting a Usage Fault/ Illegal unaligned load or store. Please, help me to trace the fault to actual offending instruction and extract additional info.
What have I done so far:
Per ARM AN209 (http://www.keil.com/appnotes/files/apnt209.pdf) I have installed a hard fault handler.
extern C void HardFault_Handler(void) { __asm volatile ( tst lr, #4 \n ite eq \n mrseq r0, msp \n mrsne r0, psp \n ldr r1, [r0, #24] \n ldr r2, handler2_address_const \n bx r2 \n handler2_address_const: .word prvGetRegistersFromStack \n ); }
Values of the registers extracted from the exception stack frame are:
HFSR is 0x40000000 indicating Forced (I do not have a separate handler for UsageFaults)
CFSR is 0x01000000 indicating UsageFault, UNALIGNED access
xSPR is 0100 0003
MMFAR is 0
BFAR is 0
pc (0x0803A758) points to
a dead loop of osRtxIdleThread.
This could not be the offending instruction, could it? What am I missing?
I have checked the RM0385 Reference manual, I see that the exception stack has been parsed properly:
My system is:
Cortex M7 (STM32F746NG..)
Keil RTOS
Once the unit is stalled, I have connected to it using SEGGER J-Link/J-Trace for Cortex M (using Ozone), stopped the program, and examined the memory contents.
Unaligned access fault trap (UNALIGN_TRP) is disabled ( per reference it means that only ... can generate this fault)
I read:
https://community.arm.com/developer/tools-software/tools/f/armds-forum/402/debugging-a-usage-fault-for-an-unaligned-memory-access
http://www.keil.com/support/docs/3777.htm (but no external SDRAM is used)
also read:
https://medium.com/@iLevex/the-curious-case-of-unaligned-access-on-arm-5dd0ebe24965
https://stackoverflow.com/questions/18269181/unaligned-access-causes-error-on-arm-cortex-m4
https://stackoverflow.com/questions/20926386/what-is-non-aligned-access-arm-keil
https://stackoverflow.com/questions/5119496/arm-unaligned-memory-access-workaround
Duplicated post:
https://community.arm.com/developer/ip-products/processors/f/cortex-m-forum/43707/unable-to-determine-offending-instruction-usage-fault-illegal-unaligned-load-or-store-cortex-m7-keil-mdk-pro
It was my first post in the forum, and it was delayed, probably due to manual moderation. Sorry about polluting. As I do not have a button to delete my post, moderators please feel free to delete it.
Do not delete it yet. I made a tiny formatting change to my original post, and it is now inaccessible tot he public due to pending moderation.
No problem. I just put the note so people know they are the same - yes, sometime our moderation system can takes time.
Regarding stack overflow - I don't have any solid evidence that it s a stack overflow. But since you said the problem happen only once in a while then stack overflow could be one possibility.
