Dear All,
Technical data sheets for the ARM7500FE and ARM7100 say that:
"In the ARM Processor the cache will be searched regardless of the state of the C bit, only reads that miss the cache will be affected."
Now the question is that whether it holds for the Cortex-A8 processors family or not?
The other question is that when switching the ARM domains whether the store buffer gets automatically drained or we have to use the barriers for this?
Many thanks in advance.
The behaviour of the SCTLR.C bit is essentially flexible per the architecture specification. Some core implementations may use it only to control allocation into the cache, some cores may use it to control both allocation and the ability to perform cache lookups altogether (effectively disabling the ability to cache data and instructions completely, except to perform maintenance operations).
Particularly in the Cortex-A8, setting SCTLR.C = 0 will disable both allocation and lookups at L1I, L1D and cause the core to disregard ACTLR.L2EN. Whether data is valid in the cache or not, the core will access the next level of memory, so it is as if the caches don't exist except to maintenance operations.
As an example on the Cortex-A7 and Cortex-A15, however, SCTLR.C only affects allocation into the caches. That is to say that with SCTLR.C = 0 on the Cortex-A15, a load/store instruction which hits in any cache level will still be serviced from that cache. A load /store instruction that misses in the caches will be serviced from the next level of memory, but that data will not then be placed into the cache for further use.
Your second question is a little less clear to answer. What exactly do you mean by "switching the ARM domains?"
Thanks for your very detailed answer. But what if this C bit refers to what is called Cacheable or C bit stored in the memory management page tables? Which is the ARM processor behavior in this case.
By domain, I am referring to what is so called a "domain" in the following definition:
"A domain is a collection of memory regions. The ARM architecture supports 16 domains. Domains provide support for multi-user operating systems. All regions of memory have an associated domain."
and by "switching the ARM domains?" I mean when we switch for example from a domain which is assigned to the kernel level accesses to a user level access domain,
Hi hnnemati,
Domains are simply an access permission model. You do not actually 'switch' between them at all - you would define the access rights for each of the 16 domains (using the DACR register) and then apply that domain ID within your block translation descriptors (i.e. it must be a translation, not a pointer to next level) page tables. The rights are very simple - no access means you will get a domain fault. A domain configured for Client access means that the AP bits are checked and therefore a permissions fault can be generated. Anything in a domain marked Manager will not check the AP bits and therefore cannot generate a permission fault.
In your page table entries you simply mark each entry with the appropriate domain. It is meant as a method for operating systems to differentiate when looking at the page tables between application and kernel code and data (and you get 16 different 'marks,' even if they can only each be one of three possible domain permission models, which allows an OS to use the domain field to track the purpose of the region of memory somewhat).
You will need at least an ISB after changing the DACR, since it requires context synchronization - but you would usually only set the DACR once at very early initialization of your application or OS kernel. There are specific barrier and cache requirements for changing page table entries - modifying the domain number included - but I am still not sure what you are asking when you ask whether the store buffer is automatically drained.
Ta,
Matt
Hi Matt,
Thanks a lot for your answer. By "automatically drained" I mean if the ARM processor evicts the store buffer entries without requiring any explicit software intervention (using specific barriers), when we switch from kernel to user space.
I would also really appreciate if you could help me with the first part of my question. If in this statement "In the ARM Processor the cache will be searched regardless of the state of the C bit, only reads that miss the cache will be affected." , C bit refers to what is called Cacheable or C bit stored in the memory management page tables, whether the statement holds for the cortex-a8 or not?
Regards,
Hamed
Hi Hamed,
When you say switch I'll take that to mean that you are changing the processor mode in the CPSR (either manually, or by returning from an exception in an approved manner). In this case, the mode switch is a context synchronization event and it will ensure that any state changes you have made will take effect upon entry to the new mode. This does imply an instruction pipeline flush (i.e. the same effect as an explicit 'isb' barrier instruction) but I could not find any architectural guarantee that the store buffer would be drained, nor anything in particular in the Cortex-A8 - it is not usually something you need to do before switching processes in an operating system (it does not matter, really, whether the writes for one OS application are still in the store buffer when you switch to another. Where it does, explicit synchronization primitives would usually be in use anyway, at the application level). If you have a concern then you should manually insert a 'dsb' barrier (see the note in section A3.8.3/A3-153 on Memory Barriers in the ARMv7-A/R Architecture Reference Manual).
In the statement you quoted, the C bit refers to the C bit in the System Control Register (SCTLR). This is the global enable for cacheability within an ARM core, although it's full effects are somewhat implementation defined - but the implementation defined effects are mitigated, as it is really not very common to modify this bit at runtime. Usually you turn it on and leave it on until you need to power down the cores at which time prevention of allocation into the cache is important so that you have a static set of data to clean and invalidate out to the next level of cache, and the next, and so on until you get to the memory subsystem. There is a really good discussion on this in section B2.2.3 (Cache enabling and disabling) of the ARMv7-A/R ARM, with the prudent points:
In ARMv7: • SCTLR.C enables or disables all data and unified caches for data accesses, across all levels of cache visible to the processor. It is IMPLEMENTATION DEFINED whether it also enables or disables the use of unified caches for instruction accesses. .. When a cache is disabled for a type of access, for a particular translation regime: • it is IMPLEMENTATION DEFINED whether a cache hit occurs if a location that is held in the cache is accessed by that type of access. • any location that is not held in the cache is not brought into the cache as a result of a memory access of that type.
In ARMv7:
Note that with SCTLR.C disabled, MMU table walks will act as if they access non-cacheable memory, too. With regards to the C bit within the translation tables, this note (in section B3.8.2) is important:
The B (Bufferable), C (Cacheable), and TEX (Type extension) bit names are inherited from earlier versions of the architecture. These names no longer adequately describe the function of the B, C, and TEX bits.
If you are used to older versions of the architecture and older page table descriptor formats this can be quite a challenge, and in fact depending on other settings the meanings of these bits completely changes and becomes an indirect index to a memory type defined elsewhere. They do somewhat confer cacheability of memory accesses, but have really no physical impact on the operation of the cache itself as the SCTLR does.
I'd suggest you have a quick read through at least section D15 of the ARMv7-A/R ARM which describes the differences between ARMv4/5 and ARMv7. Since you are coming from reading about a much older version of the architecture, section D12 (differences from ARMv6 to ARMv7) is also useful to you, but not quite as much as D15. It is arranged in such a way that you should very quickly find out there have been quite a few changes - the part which is going to be of most use is D15.3.4 (Memory model and memory ordering). Unfortunately it is quite short and summarized - the real meat of the topic is in the first few chapters of section B (and it is very long).
For your information, you can find the ARM ARM here:
http://infocenter.arm.com/help/topic/com.arm.doc.ddi0406-/index.html
And the latest Cortex-A8 TRM here:
http://infocenter.arm.com/help/topic/com.arm.doc.ddi0344-/index.html
If you have any questions as you read through, don't hesitate to ask - although usually if it is not mentioned in either of those documents, it is usually irrelevant or not worth knowing.
Thanks a lot Matt,
