HW_UINT32 dtcm, itcm;HW_UINT32 enable_memory_sharing;#define HW_TCM_ENABLE 0x1#define HW_ITCM_SIZE_32K 6#define HW_DTCM_SIZE_16K 5 enable_memory_sharing = 0; __asm__ __volatile__("MRC p15, 0, %0, c9, c1, 0":"=r"(dtcm)); dtcm |= ( 0x10104000 | (HW_DTCM_SIZE_16K << 2) | HW_TCM_ENABLE ); __asm__ __volatile__("MCR p15, 0, %0, c9, c1, 0"::"r"(dtcm)); enable_memory_sharing |= AT91C_CCFG_DTCM_SIZE_16KB; __asm__ __volatile__("MRC p15, 0, %0, c9, c1, 1":"=r"(itcm)); itcm |= ( 0x10108000 | (HW_ITCM_SIZE_32K << 2) | HW_TCM_ENABLE ); __asm__ __volatile__("MCR p15, 0, %0, c9, c1, 1"::"r"(itcm)); enable_memory_sharing |= AT91C_CCFG_ITCM_SIZE_32KB; AT91C_BASE_CCFG->CCFG_TCMR = enable_memory_sharing;
Why do you use dtcm "|=" for the configuration. I'm not sure what the reset values of the TCM configuration registers are - but you are creating a new configuration rather than updating a new one. I think you can get rid of the MRC, do "dtcm =", rather than or'ing the new data with the old configuration.Same comment applies to the ITCM.
TCM is only the same speed as cache *if* the SRAM provided in the ASIC is single cycle access, zero wait-state memory. If the design is using the bulk SRAM to provide the TCM, there is no reason why the TCM should suddely be faster than the SRAM - the physical RAM hasn't changed. If the SRAM is (for example) three cycle access, I'd expect TCM to be three cycle access. Could this mean that the TCM is slower than the cache - yes certainly.
