Is there an atomic way to enable the MMU and continue at a given virtual address?
It would be nice if there was a CP15 operation that could atomically enable the MMU and continue at a given VA.
Can the Hypervisor or ATF be used for this for EL1 or EL2. So code running on PA executes a HVC/SMC and the lower exception level enabled the higher ELs MMU and returns to a give address?
Thanks, Axel
