Our project only wants 2 cores to support NEON for cost reasons. How can I do this?
1. Can a single cluster be done?
2. Cut into 2 clusters, each with 2 cores. What is the difference between the performance of ARM HMP scheduling 4 cores and the performance of single cluster 4 cores?
Are you talking about the actual SoC you want to build?
Yes, Do you have any good suggestions?
I have learned that ARM's new DynamIQ multi-core design can fulfill my needs in a custle, but our IC design is now starting design, can not wait for the application of DynamicIQ multi-core design.
Whether the cpu core in the same cluster can be configured differently. For example, there are 4 CA53 Cores in a cluster, 2 of which need to join NEON support, and 2 of which do not need to be added.
All of the cores in a Cortex-A53 cluster must have the same NEON configuration.
If you want to study the impact of a single four core design versus a dual core, dual cluster I would recommend to use Arm Cycle Models. It would be easy to setup different simulations and assess the performance of various configurations.
The models are built on a web portal called Arm IP Exchange with easy configuration to change parameters.
Let me know if you have any questions.
Jason
