Hi Experts,
I need to access L2 TLB internal memory for A76 core (Section A6.6 of Cortex A76 TRM) . I was searching for an example code and found this for A57 core:
LDR X0, =0x0000000001000D80 SYS #0, c15, c4, #0, X0 DSB SY ISB MRS X1, S3_0_c15_c0_0 ; Move ILData0 register to X1 MRS X2, S3_0_c15_c0_1 ; Move ILData1 register to X2 MRS X3, S3_0_c15_c0_2 ; Move ILData2 register to X3 MRS X4, S3_0_c15_c0_3 ; Move ILData3 register to X4My questions are:1. which address is being accessed in the first LDR instruction? (0x0000000001000D80). What will be the equivalent address for A76 ?2. I am novice and yet to start with the instruction manual. Can anyone explain on the 3rd and 4th instructions please?
DSB SY ISBRegards,
You find the encoding of the "address" in the chapter you named: Tables A6-2 and A6-3
Thanks Bastian. As mentioned in the TRM, I have to be in EL3 to perform this operation. So, I will do a EL1 to EL3 switch before. Once I get the ILDATAn registers to X1 to X3 I have to move back to EL1, How can I read or print X1 to X3 registers in my C code once I return from this function?
Amitra29877 said:How can I read or print X1 to X3 registers in my C code once I return from this function?
Please read a book on C programming and assembly. This is basic knowledge. So maybe start with these basics before trying the heavy stuff?!
Thanks for your advice. My question was on the exception levels : will I be able to print the variables when I am in EL3 or should I return to EL1 and then try to get the variables printed.
