I was reading The Definitive Guide to ARMCortexM0/M0+ by Joseph Yiu
In Chapter 21, under section 21.4.2 GNU Compiler Collection, there is a example function with inline assembly operation:
int my_mul_10(int DataIn) {
int DataOut; __asm(" movs r0, %0\n"
" movs r3, #10\n" " mul r0, r3\n" " movs %1, r0\n" :"=r" (DataOut) : "r" (DataIn) : "cc", "r0", "r3");
return DataOut; }
In the code example, %0 is the first input parameter and %1 is the first output parameter. Since the operand order is output _operands, input_operands, and clobbered_operands, “DataOut” is assigned to %0, and “DataIn” is assigned to %1. Since the code changes register R3, it needs to be added to the clobbered operand list.
Shouldn't "DataOut" is assigned to %1 and "DataIn" to %0?
Or am I missing something here?
Actually the first sentence is the one that need fixing. The first operand (here the output operand DataOut) goes in %0, second operand (here input operand DataIn) in %1, etc.Best regards,Thomas
I am bit confused now. From the code, what I understand is that %0 is the input (DataIn) and %1 is the return value (DataOut).
Sorry for the error in the text, and a bit unclear in the descriptions.
In the code:
1st parameter (%0) : "=r" (DataOut)
2nd parameter (%1): "r" (DataIn)
3rd to 5th parameters: "cc", "r0", "r3"
Thomas's is correct - the first sentence is wrong, and might be clearer to write it as:
"In the code example, %0 is the output parameter and %1 is the input parameter."
Please note that this is an old style inline assembler format. Recent gcc support symbolic names - instead of using %0, %1..., you can use %[ _name_ ] which is much easier to read. Unfortunately I wasn't aware of this when I wrote the book.
regards,
Joseph
Ah yes indeed, it should be %1 at the top and %0 later. Sadly typos happen.
Thanks a lot Thomas.
Thanks a lot, Joseph. Learnt a lot from your book :)
Thanks for your feedback :-)
