Education Hub
Education Hub
Arm Education The Evolving Nature of Work
  • Arm Education
  • New
Education Hub requires membership for participation - click to join
More blogs in Education Hub
  • Arm Education
  • training
  • Machine Learning (ML)
Khaled Benkrid
Khaled Benkrid
April 12, 2021
 The rise of Artificial Intelligence (AI) technology and the Internet-of-Things (IoT) is giving rise to a fourth industrial revolution which is already having a fundamental impact on the nature of work and the supply & demand in labor markets; the trend is set to accelerate in the coming years. Indeed, according to the World Economic Forum’s "Future or Work Report 2020" [1], 67% of current work tasks are done by humans and 33% are automated through machines and algorithms. By 2025, the rate of automation of current work tasks will grow to 47% i.e., almost half of all work tasks. According to the same report, by 2025, 85 million jobs globally may be displaced, while 97 million new roles may emerge as a result of a new division of labor between humans, machines and algorithms. This means the overall rate of job creation is predicted to be positive, but larger numbers of current workers will need to be reskilled for new jobs.
For hundreds of years, most people remained in the same employment throughout their working life. Driven by technological advances and globalization in the past few decades, most people are now expected to change jobs several times during their working life (see Figure 1).  This change can either happen with the same employer and/or across multiple employers. This career path is often referred to as a set of “tours of duty” [2]. During a tour of duty (lasting several years on average) a worker produces tangible achievements in a particular line of business before pivoting to the next tour of duty either within the same organization or outside. Such approach allows individuals to build a portfolio of competencies over time.
Note that this shift is giving rise to horizontal market employment whereby a worker’s value serves multiple vertical markets, which potentially gives employees a greater degree of employability and flexibility either as part of a horizontally focused company/institution (e.g., a cloud service provider) or through freelancing and independent contracting. It also gives employers great flexibility and access to a potentially wider pool of talent, although compliance issues e.g., to do with employment rights and taxation across jurisdictions, and export controls, need to be looked at carefully.
Nonetheless, the COVID-19 crisis and ensuing acceleration of remote working will probably grow this type of employment further in the future.
 Employment Evolution
Figure 1. (a) Traditional employment (b) Modern employment
Addressing the above shift requires the proper education and skilling of new entrants to the job market (to meet the right jobs of the future) as well as reskilling existing workforce away from destructed jobs into newly created ones. Higher and further education institutions, alongside industry, policy makers and the third sector, have a pivotal role to play in this regard. In particular, the future proofing of the world of education and training is an economic imperative.
To do that, the community needs to build competency models for job roles [3]. Such competency models include the set of knowledge, skills, attitudes and behaviors required from workers to perform at an expected level.  For instance, the aforementioned future of jobs survey [1] revealed the following top skills (/attitudes/behaviors) for 2025.
1
Analytical thinking and innovation
2
Active learning and learning strategies
3
Complex problem-solving
4
Critical thinking and analysis
5
Creativity, originality and initiative
6
Leadership and social influence
7
Technology use, monitoring and control
8
Technology design and programming
9
Resilience, stress tolerance and flexibility
10
Reasoning, problem-solving and ideation
11
Emotional intelligence
12
Troubleshooting and user experience
13
Service orientation
14
Systems analysis and evaluation
15
Persuasion and negotiation
Table 1. Top 15 skills (/attitudes/behaviors) for 2025 [1]
The same survey revealed the following job clusters as growth areas for employment in the future.
Job Clusters 2025
Figure 2. Job clusters of the future [1]
Such requirement gathering should be performed regularly (by policy makers, industry, the third sector, educational and training organizations) and fed back to talent development units within companies as many new roles can be filled by reskilling existing workforce, especially those whose job roles have been destructed by the evolving nature of work. The same requirements should be fed back openly to educational and training organizations as they prepare new entrants or re-entrants to the job market. This cycle needs to be accelerated considerably if we are to plug the growing mismatch between demand and supply in the modern job market.
Below are some open questions that the community needs to answer, collectively:
  • What are the required foundational competencies in the various job clusters of the future? These are not expected to change considerably over time, and hence the research and development investment required to identify these foundational competencies and develop the corresponding teaching, training and assessment methods, is justified.
  • What forums, incentives and rules of engagements are required to bring together all stakeholders to match job market supply and demand? I posit that existing mechanisms are inadequate to match today's levels of job destruction and creation, let alone future ones.
  • What is the right mix of industry driven investment & leadership vs. governments’? over-reliance on one actor over the other will inevitably lead to sub-optimal outcomes.
 Let us know what you think in the comments section below, or by emailing us on education@arm.com.
References
[1] World Economic Forum, “The Future of Jobs Report”, 2000, Web: https://www.weforum.org/reports/the-future-of-jobs-report-2020
[2] R. Hoffman, Ben. Casnocha, C. Yeh, “Tours of Duty: The New Employer-Employee Compact”, 2013, Harvard Business Review, Human Resource Management.
[3] K. Benkrid, “Talent Multiplication: The Holy Grail Of Modern Organizations”, 2020, Web: https://community.arm.com/education-hub/b/khaled-benkrid/posts/talent-multiplication-the-holy-grail-of-modern-organizations
  • View
  • Hide
  • Khaled Benkrid
    Khaled Benkrid over 4 years ago in reply to Nicholas Outram
    Completely agree Nick, a structured and well funded framework for lifelong learning is necessary. There is no shortage of ideas there but a lack of long term stability, attention to detail and execution focus have meant that we're still struggling with this problem. Your last point about agree discrimination is poignant - I think the lack of rigorous competency models means that wider knowledge, behaviours and attitudes (which people develop with experience) are often neglected when it comes to recruitment, staff appraisals and remuneration.
  • Nicholas Outram
    Nicholas Outram over 4 years ago
    A thought provoking article. Many economic and societal challenges exist alongside this. As an academic in Higher Education, it's apparent how challenging it is for a mature student (mid career or change) to take time out to become a student. Loaded with financial responsibility, full-time studies is often not viable for many. There are Masters programmes and CPD courses, but I wonder if even this is always viable given the time commitment. I love the idea of lifelong learning, but funding this is a challenge. Maybe the new online model is the opportunity here? Employers may also play a key role here. For Universities to invest, they need to understand what is in demand to make courses viable. I think we know some of this. I would embrace a tighter relationship between academia and industry, so that we can support each other. For example, I like the idea of taking regular sabbaticals so that I am exposed to industry, but I suggest for most academics all over the world, work commitments and workload make this very difficult. A final point is one of age discrimination. Older people tend to be more expensive as they come with family commitments. One would hope that the value of experience is recognised, but I've observed how this is a real concern for mature students.
Arm Education
  • A lifelong circular model of education: from cradle to cradle
    Khaled Benkrid
    Khaled Benkrid
    Discover how Arm Education is shaping cradle-to-cradle learning in tech, enabling flexible, lifelong pathways in AI, SoC, and embedded systems.
    • April 25, 2025
  • A modern way to learn the Arm Assembly Language
    Kieran Hejmadi
    Kieran Hejmadi
    Elevate your Arm Assembly learning experience with the cutting-edge Arm Language Server. Learn more in this blog post.
    • January 31, 2025
  • Anglia Ruskin University: Ultra-flexible learning powers efforts to plug industry skills gaps
    Robert Iannello
    Robert Iannello
    ARU and Arm Education launched an online PG Cert in Embedded Computing, addressing skills gaps in AI and IoT through flexible, industry-focused learning.
    • December 12, 2024
