WID not present in AXI4
can you clarify to me, why there is no WID in AXI4?
  • WID is needed to support write data interleaving described in AXI3, but this isn't supported in AXI4, so no requirement to have a WID signal.
    See section A5.4.1 in the current AXI protocol spec for details of this.
    And as section A5.4.2 states, if you have an AXI3 legacy deisgn which needs a WID input, this can be generated using the ID conveyed on AWID.
