Site
Search
User
Site
Search
User
Groups
Arm Research
DesignStart
Education Hub
Graphics and Gaming
High Performance Computing
Innovation
Multimedia
Open Source Software and Platforms
Physical
Processors
Security
System
Software Tools
TrustZone for Armv8-M
中文社区
Blog
Artificial Intelligence
Automotive
Healthcare
HPC
Infrastructure
Innovation
Internet of Things
Machine Learning
Mobile
Smart Homes
Wearables
Forums
All developer forums
IP Product forums
Tool & Software forums
Pelion IoT Platform
Activity
Support
Open a support case
Documentation
Downloads
Training
Arm Approved program
Arm Design Reviews
More
Cancel
Developer Community
IP Products
System
Jump...
Cancel
System
SoC Design forum
PL031 verilog generation
Blogs
Forums
Videos & Files
Help
Jump...
Cancel
New
State
Not Answered
Replies
Subscribers
71 subscribers
Views
Users
0 members are here
AMBA
PrimeCell High-Performance Matrix
primecell
pl301
Bus Architecture
AHB
Related
Offline
nicolan nicolan
over 6 years ago
Note: This was originally posted on 19th February 2009 at
http://forums.arm.com
Pls, I need an answer to a blocking issue
I tried to generate a verilog code for PL031 connection matrix 2x3.
Unfortunely generated HSEL signal for each slave doesn't work properly.
In "AxiToAhbWrapper" output verilog file, in fact, following assign appears:
assign HSEL =1'b1;
and because this block is "copied" for all the master interface inside, then all "HSELx" signals are put high.
What's appens?!
regards
Nicola
0
Offline
nicolan nicolan
over 6 years ago
Note: This was originally posted on 20th February 2009 at
Thanks JD,
HTRANS utilization, I think, is the best way to proceed.
rgds,
Nicola
Cancel
Up
0
Down
Accept answer
Cancel
0
Offline
Colin Campbell
over 6 years ago
Hi Nicola,
The PL301 (I assume this is what you meant) is usually IP licensed directly from ARM, so you would be much better sending your questions to them directly rather than using a more public forum such as this. Their support guys are probably best placed to support their own IP.
I would guess though that the answer to your questions is that this AHB port is designed to support just one AHB slave, hence the single HSEL output, and if there are no transfers coming to your slave, the HTRANS signal will probably be indicating IDLEs.
If each of your PL301 outputs are AHB ports, each would then have a single AHB HSEL signal, each driven permanently high, and the connected slaves would be permanently selected, using HTRANS to define when a transfer is occuring (all perfectly valid).
You can also specify that the AHB port appears as an AHB master, so no HSEL signal, and you then add your own external AHB decoder block, which will generate the HSEL outputs you want, and active only when you want.
But if you've got a support agreement for PL301 with ARM (or whoever you got the PL301 from), you would get a more definite answer using that channel.
JD
Cancel
Up
0
Down
Accept answer
Cancel
By title
By date
By reply count
By view count
By most asked
By votes
By quality
Descending
Ascending
All recent questions
Unread questions
Questions you've participated in
Questions you've asked
Unanswered questions
Answered questions
Questions with suggested answers
Questions with no replies
Answered
strobe
0
6239
views
3
replies
Latest
27 days ago
by
Christopher Tory
Answered
AXI4-Relationships between the channels
0
1615
views
1
reply
Latest
1 month ago
by
Colin Campbell
Answered
How to assert PSLVERR in APB4 ?
0
1760
views
2
replies
Latest
1 month ago
by
PhanTam
Answered
How AHB Arbiter should handle granting bus masters while performing only a SINGLE transfer?
0
1675
views
1
reply
Latest
1 month ago
by
Colin Campbell
Answered
Should the SPLIT and RETRY response be given only for NONSEQ transfer?
0
2131
views
4
replies
Latest
1 month ago
by
ISHWAR GANIGER
View all questions in SoC Design forum
