AS YOU CAN SEE MY CAPTURE DATA FROM ADC CHANNEL 1 AS PREFIX a20.00000. im perplexed by this result
what might be the reason
Programming error is the most common reason. If not SW, then HW error. If not HW error, then magic.
gnsh said:what might be the reason
RealTerm just displays what you send it - so your code must be doing it!
Almost certainly the problem is in sending the data to the terminal - nothing to do with the ADC.
