I tried using variable names ( AD0 , Ain0 ) non of them was identified in Keil's logic analyzer , and also non of VTREG signals was related to ADxx ( Update : discussion moved to https://community.arm.com/developer/tools-software/tools/f/keil-forum/45258/how-to-simulate-analog-input-to-adc0-pin-on-logic-analyzer/162319#162319 )
does my question need more details ?
Yes.
I want to simulate performance of a code uses ADC module in MKL25Z board using Keil uVision5 simulator , this requires supplying virtual signal to one of its ADC channels , i tried adding variables to logic analyzer ( AD0 , AD00 ) but it gave me "Unknown signal error , so i typed " DIR VTREG " in command window and non of the signals was related to AD module ( this explains the error ) , so i want to know how to enter a signal with certain value and also how to link this signal to a particular pin in my board .
Did you try Keil's support? Should be the first to contact for a Keil specific question. Or the Keil forum.
Thanks , i'll try the keil forum
