I was going through the Ordering part of the AXI4 Spec where I could find these:
Here I had few question on the highlighted spec which is unclear to me by reading.
1) For the Same ID the initiated request should reach the target in a same order in which they are issued If the request is to peripheral device or to the memory device with overlapping address.2) If a master issues a Transaction in one direction and it has issues another request without getting the response in the other direction then there is no ordering guarantee between two transaction
Both of the line from the spec seems to be conflicting to me unless 2nd one is applicable only for the request with different ID.
As per my understanding:
1) if there are 2 request with Address A0 and A1 and ID is same for both then request with address A0 should reach the target device 1st followed by request with address A1 given Address with A0 request is initiated first by the initiator followed by address with A1 request.
2) if there are 2 request with the same address A0 and the same ID is used for both of the request then whichever request is launched from the Initiator first should reach the target first In case of memory transaction.
3) if there are 2 request with Address A0 and A1 and ID is same for both then there is no ordering requirement for the request given the A0 and A1 address transaction doesn't have overlapping address in case of memory transaction.
Can anyone help me with above points ?
Rajneesh
HI Rajneesh Mishra
Apologies for the delay in responding. This forum is for questions about how to use the Arm Community. Please could you take a look at Support forums and let me know which forum I can move this question to?
Oli
Arm Community Manager
Hi Oliver Beirne ,
Thanks for clarifying, I have posted the question in Support forum now.
AXI4 ordering Model.
View all questions in Community Help forum
