Tools, Software and IDEs blog GNU ARM Eclipse: open source tools with (experimental) CMSIS Pack support
  • Open Source Projects
  • CMSIS
  • Tutorial
  • GNU Arm Eclipse
Liviu Ionescu
Liviu Ionescu
July 17, 2014
5 minute read time.
Overview
The GNU ARM Eclipse project includes a set of open source Eclipse plug-ins that enhance Eclipse CDT (C/C++ Development Tooling) with the specific functionality required to create/build/debug/manage ARM (32-bit) and AArch64 (64-bit) applications and static/shared libraries, using the latest GNU ARM GCC toolchains. These plug-ins will be the foundation of a future integrated suite intended to meet the growing demands of entry level users and small companies.
Project sites
The main source of information for GNU ARM Eclipse is the project site GNU ARM Eclipse (note: no longer functional. Alternative website: GNU MCU Eclipse) currently with the following home page:
GNU Arm Eclipse home page
The Git repositories and all public releases are available from SourceForge.
SourceForge GNU Arm Eclipse plug-in
Install
The recommended way to install the GNU ARM Eclipse plug-ins is to use the Eclipse standard install/update mechanism: in the Eclipse menu go to: Help → Install New Software… and use the update site location.
GNU Arm Eclipse install
The managed build
The managed build plug-in allows to create C/C++ managed projects and to configure an extensive list of compiler and linker options.
GNU Arm Eclipse tool settings
The GNU ARM Eclipse build plug-in also provides extensive configuration options for selecting the toolchain and to portably manage the toolchain path:
GNU Arm Eclipse toolchain
Extra build steps
In addition to building the ELF file, the build plug-in can also create a binary file (ihex, srec, binary) to be programmed in the processor flash memory, create a listing, and display the program size.
Arm GNU Eclipse extra build
Discovery Options and Indexing
In order to allow Eclipse users to navigate to definitions and declarations, to allow smart completion, refactoring and all these nice features, the CDT needs to have exactly the same knowledge of the source files as the compiler. For this, it also needs to know the system headers used at compile time and the default preprocessor definitions issued by the compiler. GCC provides a magic combination of command options to do this (-E -P -v -dD ${plugin_state_location}/specs.c), so the CDT needs to issue the proper compiler commands (one for each language, C & C++). The build plug-in provides these details, for each toolchain.
Arm GNU Eclipse preprocessor
The result of a proper discovery setting is a correct set of preprocessor definitions that reflect the compiler options and a correct set of include folders:
Arm GNU Eclipse t1cpp
Functional ready to run templates
For beginners, who need initial help to put together all details for their first project, a complete sample with startup code, linker scripts, semi-hosting support and all necessary options already set, can be a major time saver.
Elaborated templates are available for the STM families of processors STM32F[01234], and for some Freescale KL processors. They create the classical application that blinks a LED, and, specific for the Debug configuration, prints a string on the tracing (SWV or semi-hosting) output.
Arm GNU Eclipse target processor settings
For processors from other families, there is also a generic Hello World ARM Cortex-M3 Project template.
Debugging support
During the lifetime of a project, creating/editing source files and building binaries are certainly important activities, but in many cases the most time is spent during debugging sessions, therefore a reliable debugging environment is an absolute must.
There are many debugging techniques and tools, but GNU ARM Eclipse recommends two solutions:
  •   the SEGGER J-Link probe with its integrated GDB server, via the J-Link plug-in
  •   the OpenOCD GDB server for many other JTAG probes
The preferred solution is the SEGGER J-Link, and the J-Link plug-in allows to configure most relevant J-Link GDB server options:
Arm GNU Eclipse t1cpp j-link
Packs support
Packs refers to a new modular technology, intended to simplify distribution of software and documentation. The main difference from usual libraries or source archives is that the actual source/object files are accompanied by some form of metadata, defining the dependencies between files, the use of constraints and conditions, plus lists of devices the software runs on, with full descriptions, memory map, registers and peripherals, etc.
The GNU ARM Eclipse Packs Support plug-in is intended to manage (list/install/inspect/remove) packs from multiple sources. It currently implements the specifications of CMSIS Packs v1.2, as defined by ARM Keil, with some extensions.
Arm GNU Eclipse packs
The importance of the packs technology is amazing, and there are many useful things available in the packs; unfortunately most of the existing ones, being created by ARM/Keil, were designed with Keil MDK in mind, so are expected to be included in projects compiled with the outdated ARMCC compiler; moreover all available examples can be used only with Keil MDK, and are of no direct use for Eclipse and GCC environments.
For the moment, inspecting the content of the packs is all that can be done, but the packages also include some portable files, that can and will be used in future versions of the plug-ins, for example:
  • The list of supported devices and memory maps will be used to associate devices to projects; this will allow to automatically fill in some of the compile options, like the architecture (M0/M0+/M3/M4); even more importantly, it will allow to automatically generate the linker scripts with the correct values (avoiding severe headaches for many users, especially beginners);
  • The detailed list of device peripherals and the register bits will be used to extend the debug perspective with a detailed view presenting the register bit values, a very convenient feature when developing embedded software;
  • The list of documentation files (PDF or CHM) will be available on a project view, for easy access to the specific device or board documentation;
  • The vendor CMSIS headers and source files will be used in the future version of the project template.
And, in the mid-term future, the GNU ARM Eclipse templates will be fully replaced with component based projects, allowing an easy update and advanced configurability for projects.
  • mian qi
    mian qi over 4 years ago in reply to Liviu Ionescu
    I want to try this method on NUCLEO G474RE, could you give me some advice for startup? I don't know how to make a new project for ti.
  • Liviu Ionescu
    Liviu Ionescu over 8 years ago
    [GNU ARM Eclipse plug-ins v3.2.1-201701141320 released](gnuarmeclipse.github.io/.../)
    Version 3.2.1-201701141320 is a new major release; the main change is adding support for **Eclipse Neon.2 (CDT 9.2)**.
    Diego Russo
    Diego Russo
    • October 9, 2025
  • Python on Arm: 2025 Update
    Diego Russo
    Diego Russo
    • August 21, 2025
    Stephen Theobald
    Stephen Theobald
    • July 18, 2025
