Tools, Software and IDEs blog Debug the Arm Trust Firmware, U-boot and Linux Kernel on Juno-r2 board from source level with Arm Development Studio
  • Juno Arm Development Platform
  • Arm Trusted Firmware
  • U-Boot
  • Debugging
Kaiyou Wang
Kaiyou Wang
September 4, 2023
4 minute read time.
Many users need to debug code from source level. This blog describes how to use Arm Development Studio (Arm DS) to debug the Arm Trust Firmware (ATF), U-boot, and Linux Kernel on the Juno-r2 platform at the source level.
In this blog post, we assume that the Trust Firmware, U-boot, and Linux kernel images are already uploaded to the SD-card storage on the Juno-r2 board, as the following figure shows:
 Image files on SD card
The primary CPU after reset is Cortex-A53_0. Other cores 2 Cortex-A72, 3 Cortex-A53 are in powerdown state, as the following figure shows:
 Only Cortex-A53_0 is power on
The version of Arm DS is 2023.0. In Arm DS, to set up the Juno-r2 connection, click the Connect Only option like the following figure shows:
 Connect only option
This blog post describes the debug skills in the following topics:
  • Debug the Arm Trust Firmware
  • Debug the U-BOOT
  • Debug the Linux Kernel
Debug the Arm Trust Firmware (ATF)
When the debugger connects to the target and stops the CPU running, it halts at ATF BL1 at EL3. If you want to debug the BL1, you must add the symbol file, bl1.elf, to the debugger like the following figure shows:
 Add the symbol file
If the debugger and the source code are on different Host machines you must set up a path mapping for the debugger to locate the source code. This blog post describes the example where the Arm DS runs on a Windows system, but the source code is on a Ubuntu system. Therefore, you must set up a mapping Z: disk to access the source code by using Samba service, as the figure shows:
 Edit the Substitution
 Edit Substitute Path
The following figure shows you the source code on the Arm DS Window View. You can debug the code from source level.
 See the source code
Make sure that the Symbol Loading EL and the Code running EL are at the same address space. For example, when the CPU is stopped at EL3 and you want to add the BL2 Symbol file to the debugger, you must add an offset EL1S:0x0 with the EL1S: prefix:
 Load file with EL1S prefix
The EL1S: prefix is added because the BL2 runs at EL1S. If you do not add the EL1S: prefix, the debugger loads the symbol file at the current EL address space, EL3.
The offset EL3:0x0 is needed when loading the BL31 symbol file, because BL31 runs at EL3 while BL2 runs at EL1S.
 Add symbol file with EL3 prefix
Debug the U-boot
If you want to debug the U-boot that runs at EL2N address space, you do not need to add the prefix  offset when the CPU is stopped at EL2, as the figure shows:
 Add u-boot symbol file
During the U-boot execution, the U-boot does the relocation of code section and data section. Therefore, you must reload the symbol file to the debugger with the correct offset that U-boot is going to use.
On the Juno-r2 platform, you can see the offset value 0x000000001ef6e000 with the U-boot command bdinfo as the following figure shows:
 u-boot boardinfo
Therefore, you add the Symbol file u-boot with the offset value EL2N:0x1ef6e000.
 Add u-boot symbol file with EL2N prefix
Debug the Linux kernel
Running the U-boot command printenv shows you the kernel load address is 0x80080000. The kernel entry address is 0xffffff8010080000, and you must add the symbol file, vmliux, with the offset 0x80700000000, 0x80080000-0xffffff8010080000. The figure shows this:
 Printevn on U-Boot shell
 Kernel ELF Header
 Add Kernel Symbol file with offset
The following figure shows you can view and debug from the assembly code at EL2N address space now.
 See the Kernel boot source at EL2
There is an EL switch from EL2 to EL1, so you must add the symbol file again with the same offset value after the kernel is switched to EL1.
 Add the kernel symbol file with offset again
As shown in the following figure, you can view and debug from the assembly code at EL1N address space.
 See the Kernel boot code at EL1
There is an MMU mapping from physical address space to virtual address space. Therefore, you must add the symbol file again without the offset value after the MMU is enabled.
 Add the kernel symbol file without offset
As shown in the following figure, you can view and debug the code from source level at EL1N address space.
 See the Kernel source code after MMU
For more information about debugging the Armv8-A Linux Kernel with DS-5, see the blog Debugging the Armv8-A Linux Kernel with DS-5.
There are some differences between Arm DS debugging on the Juno-r2 hardware platform and debugging on the FVP:
  • The software breakpoint does not work on the Juno Kernel debugging. This is because the code section is read-only and does not allow writing operations. For details, see the document Why does Arm DS or DS-5 software breakpoint not work for Linux kernel debug?
  • The FVP debug function is implemented by the Iris or Component Architecture Debug Interface. The FVP does not model CoreSight debug and trace components so any values contained in CoreSight debug registers cannot be trusted.
    Diego Russo
    Diego Russo
    • October 9, 2025
  • Python on Arm: 2025 Update
    Diego Russo
    Diego Russo
    • August 21, 2025
    Stephen Theobald
    Stephen Theobald
    • July 18, 2025
