Servers and Cloud Computing blog Assessing AWS Graviton2 for running WRF
  • GCC
  • MPI
  • infrastructure
  • Neoverse
Phil Ridley
Phil Ridley
August 17, 2020
5 minute read time.
Operational weather forecasting is key to informing many important decisions that are made in agriculture, marine, air transport, environment, military, financial, and other sectors. The WRF (Weather Research and Forecasting) model is a widely used US model that can simulate forecasts based on actual atmospheric conditions (observations). Real-time forecasting applications can then use these results to make informed decisions.
Over the last few years weather researchers have been investigating the use of cloud resources to run their models, with WRF [1] being a popular example. Access to such flexible resources is expected to enable more researchers the ability to perform advanced WRF simulations [2]. In this blog, we discuss running WRF on the AWS Graviton2 processor, based on Arm's Neoverse N1 cores.
Background to WRF
The WRF model is a numerical weather prediction system designed for atmospheric research and operational forecasting applications. WRF has been developed since the late 1990s through a collaborative partnership between.
  • National Center for Atmospheric Research (NCAR)
  • The National Oceanic and Atmospheric Administration (NOAA)
  • The U.S. Air Force (USAF)
  • The Naval Research Laboratory (NRL)
  • The University of Oklahoma (OU)
  • The Federal Aviation Administration (FAA)
WRF features two dynamical cores.
  • The ARW (Advanced Research WRF)
  • The NMM (Nonhydrostatic Mesoscale Model)
This enables WRF to support a wide range of meteorological applications across scales from 0.001-1000kms. There are over 30,000 registered WRF users world-wide.
The WRF Source Code
Releases of the WRF source code are available to download here. This blog discusses version 3.9.1.1, so that we can compare performance with existing results and use readily available data sets for reproducibility. The latter is not possible from WRF version 4.
WRF uses both MPI and OpenMP for parallelization, and also requires the following external libraries: an MPI distribution (for example, Open MPI, MPICH, and so on), HDF5, NetCDF-C NetCDF-Fortran.
Building WRF
Instructions how to build WRF are given on the Arm community GitLab pages. This is a straightforward process. The environment variables HDFDIR and NETCDF need to be set to the location of the HDF5 and NetCDF installations and the stanza set in the file.
WRFV3-3.9.1.1/arch/configure_new.defaults
Then execute the configure script (in dm+SM mode), followed by the build script. To facilitate a fair comparison we will use the Gnu compiler toolchain (GCC) version 9.3.
WRF Performance Benchmarks
The two WRF benchmarks we use are the Continental U.S. (CONUS) 2.5km and 12km: CONUS 2.5km and CONUS 12km. CONUS 12km is a 48-hour simulation with a time step of 72 seconds at October 24, 2001. The benchmark period is for hours 25-27 starting from a restart file at the end of hour 24. CONUS 2.5km is a 9-hour simulation with a time step of 15 seconds at June 4, 2005. The benchmark period is for hours 6-9, starting from a restart file at the end of hour 6. Since CONUS 2.5km is at a much higher resolution than CONUS 12km, this is the larger case, making it much better for demonstrating processor scalability.
For performance testing, we ran CONUS 2.5km and CONUS 12km on up to 12 AWS Graviton2 HPC instances (c6g.16xlarge). Each instance has 64 vCPUs (with a vCPU corresponding to 1 CPU core), 128GiB Memory, AWS Enhanced Network running at 25Gbps and Elastic Block Store (EBS) filesystem running at 19Gbps.
Single Node Performance
To optimize single-node performance we first determined the best combination of MPI task/OMP thread to use for each test. For CONUS 12km Figure 1 shows the lowest time per simulation time-step (0.33 elapsed seconds) could be achieved by using 8 MPI tasks with 8 OMP threads.
Figure 1: Mean Time per Step for CONUS 12km
Similarly, for CONUS 2.5km, Figure 2 shows the lowest time per simulation time-step (4.97 elapsed seconds) could be achieved by using 32 MPI tasks with 2 OMP threads. This can be attributed to vectorization of the key loops helping more, whereas the (smaller) CONUS 12km test can benefit from memory-bandwidth alone.
 Figure 2: Mean Time per Step for CONUS 2.5km
Multi Node Performance
CONUS 2.5km is known to scale well and is therefore suitable to test performance of the AWS Enhanced Network across several nodes. Figure 3 shows results running this benchmark on up to 12 nodes with AWS Graviton2 instances. Per-node we use 32 MPI tasks with 2 OMP threads. As CONUS 2.5km is of fixed size, the number of grid points per MPI task decrease as we use more nodes. Performance of the AWS Enhanced Network enables excellent scalability, and this agrees with the almost linear scalability reported in [3].
Figure 3: Strong Scaling for CONUS 2.5km
Performance Comparison
For a brief performance comparison with other AWS instances, we also tested WRF on c5a.16xlarge (AMD EPYC 7571), c5.18xlarge (Intel® Xeon® Platinum 8175m) and c5n.18xlarge (Intel® Xeon® Platinum 8259CL). Again, using the same Gnu built software stack with the following flags for WRF.
-Ofast -march=native -fopenmp -frecursive -funroll-loops
Results for CONUS 12km (Figure 4) and CONUS 2.5km (Figure 5) show the best performance is achieved with the AWS Graviton2. This is due to both CPU capability and maturity of the Gnu compiler for Arm architectures.
Figure 4: Comparison of CONUS 12km Across AWS Instances
Figure 5: Comparison of CONUS 2.5km Across AWS Instances
We have demonstrated how easy it is to run a widely used weather forecasting application, WRF on AWS Graviton2, which is based on Arm Neoverse N1 cores. The AWS platform as a whole enables excellent scalability. By comparing performance of WRF with a selection of other AWS instances, the AWS Graviton2 shows the overall fastest time to solution.
At the time of writing, c6g instances are available at a 20% lower price than equivalently configured c5 instances. In terms of cost per simulation, for WRF this means at least 45% lower cost than the c5 instances.
See Arm Infrastructure solutions for HPC
References
[1] Goga, K., Parodi, A., Ruiu, P., Terzo, O., Performance Analysis of WRF Simulations in a Public Cloud and HPC environment, Volume 611, p. 384-396, 2017.
[2] Powers, G. Jordan, and others, The Weather Research and Forecasting Model: Overview, System Efforts, and Future Directions, Volume 98(8), Bull. Amer. Meteor. Soc., p. 1717–1737, 2017.
[3] https://www.amd.com/system/files/documents/wrf-and-amd-epyc-the-right-combination-for-weather-modeling.pdf
  • Cherno
    Cherno over 1 year ago in reply to Phil Ridley
    Thank you for solving my problem. My results are now very close to Figure 1, and your blog has been a great help to my learning  :)
  • Phil Ridley
    Phil Ridley over 1 year ago
    Thanks for getting in touch. In Figure 1 I only used the last 149 timings per step to produce an average and I also switched off writing of output files, so the higher figures are not included in that average.
  • Cherno
    Hi. Thank you for your blog. I am testing the performance of conus12km on my machine, but I have some questions about my data. My time per step is close to 0.35s, which is similar to the blog's data, but some data points are above 1 second. After checking the information, I believe it is due to the radiation physics step (which occurs about once every 10 iterations, and this step takes 1.6s) and the time for writing output files (about 10s each time). In Figure 1 of the blog, when calculating the time per step, were these times included? Because if I include the time for writing output files, the time per second would be many times higher than 0.35 seconds.
  • bsotelo
    bsotelo over 2 years ago in reply to Phil Ridley
    Indeed, there are a few other things I missed. First, I only re-compiled pointing to armpls on LDFLAGS_LOCAL. I did not also point to FCOPTIM. I'll recompile it with FCOPTIM. Also, I've been running "mpirun -np #CORES wrf.exe" and no other arguments but based on another blog post of yours, even though the armpls are required when checking "ldd wrf.exe", they still need to be linked with "-lm" flag. I hope I encounter improvements here. What's your suggestion to measure wall clock time? I notice it takes about 5-10 minutes for the model to be loaded (especially the CONUS. 2.5km ), before the computation starts. I didn't find an explicit walltime/elapsed time output in any of the logs.
  • Phil Ridley
    Phil Ridley over 2 years ago in reply to bsotelo
    No problem. Thanks for reporting back on the results. Unfortunately, it looks like you're not going to get any further performance with the ArmPLs. As this is an AWS Graviton2 you're using, it looks like the standard OS supplied routines are already optimized to the same level. It's always worth trying all options though.
    Marc Meunier
    Marc Meunier
    • October 13, 2025
    odinlmshen
    odinlmshen
    • October 13, 2025
    odinlmshen
    odinlmshen
    • October 13, 2025
