Servers and Cloud Computing blog Arm CMN S3: Driving CXL storage innovation
  • Edge Computing
  • Neoverse
John Xavier Lionel
John Xavier Lionel
February 24, 2025
3 minute read time.
The Arm CMN S3 (Coherent Mesh Network) interconnect is at the forefront of enabling high-performance, scalable, and efficient solutions for modern compute and storage architectures. With its ability to seamlessly manage coherent communication and memory sharing, the Neoverse CMN S3 is a transformative solution for modern storage architectures. Purpose-built to support Compute Express Link (specifications, CMN-S3 facilitates seamless communication between compute and storage, enabling next-generation devices.
As data-centric applications grow, technologies like Compute Express Link (CXL) are revolutionizing the storage landscape. Neoverse CMN S3 plays a pivotal role in enabling high-performance, scalable storage devices configured as CXL Type 1 (accelerators) and Type 3 (memory expanders). By bridging compute and storage, Neoverse CMN S3 addresses the demands for efficiency, low latency, and coherence in modern data centers thus delivering unmatched performance and flexibility for today’s data-intensive workloads.
The adoption of CXL-enabled storage solutions is accelerating, with hyperscalers, enterprise IT providers, and cloud service providers all recognizing the benefits of memory disaggregation. CMN-S3, with its ability to efficiently route, share, and manage memory resources, is a key enabler of this paradigm shift.
Looking ahead, we can expect CMN-S3 to drive innovation in areas for example:
  • Composable Infrastructure: Disaggregating compute and memory resources to build highly efficient, scalable architectures
  • AI and HPC Storage Acceleration: Optimizing data access speeds for workloads requiring vast amounts of memory
  • Edge Computing: Enhancing storage solutions for latency-sensitive edge applications where real-time data processing is critical
By integrating CXL Type 3 capabilities, CMN-S3 is helping redefine the storage landscape, ensuring that future storage architectures are more flexible, scalable, and cost-effective. As the demand for high-performance, memory-centric computing grows, solutions like CMN-S3 will be at the core of this technological evolution.
Neoverse CMN S3 overview
Neoverse CMN S3 supports CXL.mem(Type3) and CXL.cache(Type1) functionality and is complaint with CXL specification revision 2.0 and CXL 3 revision 3.0 version. The CMN S3 has 32 CCG devices (CXL Gateway) supporting Coherent Mesh Link(CML_SMP) or CXL3.0 and have 512-bit CXS Issue B interface.
A diagram showing the CMN S3 with branches for high perf, secure and scalable interconnect.
The Neoverse CMN S3 also supports homogeneous and heterogeneous multi-chip system topologies. CXL Type1 devices can be attached to CMN S3 where each CXL type1 device is considered as a caching agent, and since CMN S3 is CXL3.0 complaint it also supports multiple caching agents behind a CXL cache port.
Homogeneous multi-chip system
A diagram showing the homogeneous multi-chip system.
 This example system has the following characteristics:
P0 P1 P2 P3
•  128 RN-Fs
•  16 RN-Is
•  4 PCIe RN-Is
•  4 coherency domains
•  128 RN-Fs
•  16 RN-Is
•  4 PCIe RN-Is
•  128 RN-Fs
•  16 RN-Is
4 PCIe RN-Is
4 coherency domains
•  128 RN-Fs
•  16 RN-Is
•  4 PCIe RN-Is
•  12 CXL Type1 devices
•  2 CXL Type3 devices attached
•  1 CXL Type3 device attached
The Neoverse CMN S3 also supports security features like and host side data encryption for data stored on a CXL type 3 device. Host side MPE is expected to be enabled when a CXL switch and/or CXL devices are not part of Host’s trusted compute base.
The CMN S3 enables CXL Dynamic Capacity Devices which address the growing need for flexible and scalable memory solutions in modern data centers. A key use case involves memory pooling, where multiple servers dynamically access a shared memory resource to handle fluctuating workloads. With CMN-S3’s advanced coherence management and low-latency interconnect, these devices enable real-time scaling of memory resources, ensuring optimal performance without overprovisioning. This makes CMN-S3 integral to supporting demanding applications like AI training, real-time processing, in-memory databases, and multi-tenant cloud environments while reducing costs and enhancing resource utilization.
Kioxia: A pioneer in CXL and Neoverse CMN S3 adoption
Kioxia, a global leader in memory solutions, has embraced Neoverse CMN S3 for its next-generation CXL devices. The company is developing advanced storage architectures, leveraging Neoverse CMN S3 to deliver shared memory solutions with high bandwidth and low latency.
Kioxia aims to commercialize CXL-enabled memory technologies that transform pooled storage and data center scalability. This underscores the industry’s shift toward coherent, high-performance CXL ecosystems powered by interconnect solutions.
  • John Xavier Lionel
    John Xavier Lionel 7 months ago
    All good.
    Marc Meunier
    Marc Meunier
    • October 13, 2025
    odinlmshen
    odinlmshen
    • October 13, 2025
    odinlmshen
    odinlmshen
    • October 13, 2025
