Operating Systems blog Workaround for Unable to load native library: libnative-activity.so
  • android ndk
  • Android
  • java
  • native
  • native-library
  • workaround
Myy
Myy
May 23, 2016
1 minute read time.
So, another bug I had to deal with NativeActivity and for which I have no clear solution but a workaround for.
The problem
I compiled a version of libnative-activity.so that depends on my own library, libmyy.so, in order to add more flexibility during the testing process.
However, when trying to load the app, the app crashed with the following error :
05-23 22:59:00.650: E/AndroidRuntime(4758): Caused by: java.lang.IllegalArgumentException: Unable to load native library: /data/app-lib/my.pack.name-2/libnative-activity.so
The workaround
  • Create a java class that subclasses android.app.NativeActivity and load the libnative-activity.so library with System.loadLibrary, in a static initialiser.
  • Edit AndroidManifest.xml to use this library, and remember to set android:hasCode to true in the <application> tag.
Example
Here the java class will called NativeDebug
app/src/main/java/my/pack/name/NativeDebug.java
package my.pack.name;
import android.app.NativeActivity;
public class NativeDebug extends NativeActivity {
  static { System.loadLibrary("native-activity"); }
app/src/main/AndroidManifest.xml
<!-- The package name is generally set up by gradle. It is not very important here-->
<manifest xmlns:android="http://schemas.android.com/apk/res/android"
          package="my.pack.name">
  <!-- Actually this .apk Java has code ! Set hasCode to true. Else your NativeDebug
        class will not be inserted in the final apk and your app will crash failing to find it. -->
  <application
      android:allowBackup="false"
      android:fullBackupContent="false"
      android:icon="@mipmap/ic_launcher"
      android:label="AppName"
      android:hasCode="true">
    <!-- Our activity is the built-in NativeActivity framework class.
         This will take care of integrating with our NDK code. -->
    <activity android:name=".NativeDebug"
              android:configChanges="orientation|keyboardHidden">
      <!-- Tell NativeActivity the name of or .so -->
      <meta-data android:name="android.app.lib_name"
                 android:value="native-activity" />
      <intent-filter>
        <action android:name="android.intent.action.MAIN" />
        <category android:name="android.intent.category.LAUNCHER" />
      </intent-filter>
    </activity>
  </application>
</manifest>
Note that this AndroidManifest.xml is based on the one provided with the NDK sample named "native-activity".
Then
./gradlew installDebug
And try your application. In my case, it worked ! The library was loaded, my library was loaded too in the process, and the native code in my library was executed !
I still do not understand why NativeActivity.java tries to load libraries with a native C++ method named loadNativeCode. However, I do understand that loadNativeCode returns 0 when trying to load my libnative-activity.so file and NativeActivity in return throws an exception, with no hint about the problem whatsoever. A slightly more useful exception message seems to have been added 6 months ago, though.
In the case that System.loadLibrary fails to load the library, your app will still crash but with a nice and helpful error message that you can use to solve the problem, this time.
  • Enhancing Chromium’s Memory Safety with Armv9
    Richard Townsend
    Richard Townsend
    The Arm Open-source Software team is delighted to mark the release of Chromium M115, with experimental support for Arm’s Memory Tagging Extension (MTE).
    • August 7, 2023
  • New Memory Tagging Extension User Guide for Android OS Developers
    Roberto Lopez Mendez
    In this blog, read about what to expect with the new MTE User Guide for Android OS.
    • May 25, 2023
  • Enhancing Chromium's Control Flow Integrity with Armv9
    Richard Townsend
    Richard Townsend
    This blog explains how Control Flow Integrity, an Armv9 security feature, works on the newly launched Chromium M105.
    • October 11, 2022
